Swizzat Posted April 16, 2009 Report Posted April 16, 2009 where do i find the signal for the tacho on a 4AGZE as i have a taco-less nova(rolla) and i wanna put one in. any help would be much appricaited cheers Quote
SLW42 Posted April 16, 2009 Report Posted April 16, 2009 the black wire should go to the negitive of the ignition(to tell what revs it's doing) and then red goes to ignition power(so when you turn the key on the tacho turns on and then you have the power wire for the lights which is self explanitory run it to a park light wire what brand of tacho do you have if it is autometer there wil be two wires that come out the back of the tacho and you will have to cut a 1 wire for a 6 cylinder and both for a 4 banger and leave them alone for a v8 speco meter i think there is just a switch at the back of the tacho for how many cylinders it has Quote
Hiro Protagonist Posted April 16, 2009 Report Posted April 16, 2009 mr ae71 said: the black wire should go to the negitive of the ignition(to tell what revs it's doing) and then red goes to ignition power(so when you turn the key on the tacho turns on and then you have the power wire for the lights which is self explanitory run it to a park light wire what brand of tacho do you have if it is autometer there wil be two wires that come out the back of the tacho and you will have to cut a 1 wire for a 6 cylinder and both for a 4 banger and leave them alone for a v8 speco meter i think there is just a switch at the back of the tacho for how many cylinders it has Since a fair few GZEs are DLI, this makes things a bit harder. Quote
Swizzat Posted April 17, 2009 Author Report Posted April 17, 2009 its a "drift" brand one, it has a switch for it, i just need to get the signal of the negative side of the coils then do i? Quote
Roo Posted April 17, 2009 Report Posted April 17, 2009 Jason said: I though 4agze ecu's have a tach out? true that Quote
Swizzat Posted April 17, 2009 Author Report Posted April 17, 2009 i have a SAFC with a tachometer, could i wire it off that? and where would it be??? Quote
Kebin[RL] Posted April 21, 2009 Report Posted April 21, 2009 Build this circuit and wire it to each of the two coil packs to have an accurate tacho output. Quote
Kebin[RL] Posted April 21, 2009 Report Posted April 21, 2009 Jason said: I though 4agze ecu's have a tach out? They don't. Quote
spikey Posted August 8, 2009 Report Posted August 8, 2009 I have just replace my non tacho cluster with a tacho one for my Ae95,everything works except for the tacho,does anyone which wire I'm missing to get the tacho to work ? Thanks Terry Quote
the witzl Posted August 17, 2009 Report Posted August 17, 2009 (edited) Kebin said: They don't. Incorrect.... mostly. You can use the IGf signal as a low level (5V) tacho signal. I'm also quite certain that the ignitor has a dedicated tacho output as well. If you have an old style tacho that used to connect to the coil negative terminal, you might need a tacho booster to get the tacho to work from the low-level tacho signal. See here - http://www.toymods.net/forums/showthread.php?t=22574 Edited August 17, 2009 by the witzl Quote
