YellaKE20 Posted April 10, 2009 Report Posted April 10, 2009 I am trying to take out the rear seat in my 2-door KE20 but can't seem too get it out?......have removed the two lower bolts on the front of the seats but l can't see any more bolts to remove to get them out. Do l need to remove the parcel shelf to get to the other bolts or are there any special way to slide the seats out? Any help would be great, after removing the entire engine, and interior in half a day getting stopped by this is giving me the sh**s. Thanks for your help. p.s. checked int he boot too but there seems to be no bolts holding the seats in from there! Quote
Raven Posted April 10, 2009 Report Posted April 10, 2009 (edited) Stupid double post! Edited April 10, 2009 by Raven Quote
Raven Posted April 10, 2009 Report Posted April 10, 2009 You need to push back the seat base and get the two hooks that the bolts bolt into over the support on the floor. To get the seat back out, there are two bolts behind the seat base that the seat belts anchor to, so undo those and slide the seat back up towards the roof and it will unhook. Quote
drc_ke20 Posted April 10, 2009 Report Posted April 10, 2009 +1 here Raven is right thats how you remove the rear seat. Quote
YellaKE20 Posted April 10, 2009 Author Report Posted April 10, 2009 Raven said: You need to push back the seat base and get the two hooks that the bolts bolt into over the support on the floor. To get the seat back out, there are two bolts behind the seat base that the seat belts anchor to, so undo those and slide the seat back up towards the roof and it will unhook. Thanks Raven, will give it a go today. Quote
