Ae71Rola Posted March 25, 2009 Report Posted March 25, 2009 Hey guys, i've got and Ae71 auto and gonna convert it to manual as i'm doing a 4age conversion... want to know if sprinter pedal setup will fit? And if anyone has done the conversion themselves would like some help... located in Adelaide, Western Suburbs Quote
beerhead Posted March 25, 2009 Report Posted March 25, 2009 Yes, it is usable, but will require mods to fit. An AE71 cluster is the way to go if you want a bolt in conversion. Quote
Ae71Rola Posted March 26, 2009 Author Report Posted March 26, 2009 thanks man... do u know how easy it is to do? Quote
LukeAE71 Posted March 26, 2009 Report Posted March 26, 2009 thanks man... do u know how easy it is to do? Well I do not know how to use a sprinter pedal setup, however.... If you search this topic you will find someone has laid out all the information for you in perfect working order and this is what I used to do mine. In all honesty as much as they are hard to find, an AE71 Manual Pedal Box is the way to go as it is a full bolt in affair. If you get stuck with it, PM me and I can give you some pointers as I have done mine just recently. I used the factory pedal box though. Quote
Ae71Rola Posted March 26, 2009 Author Report Posted March 26, 2009 thanks bud... what state are you in! yeah i'm gonna source out a Ae71 setup... i gotta get a selector as well. as the box i bought doesn't have one :-( Quote
jordan_ke Posted March 26, 2009 Report Posted March 26, 2009 Get a T18 pedal box mate, easier to use than an 86 item Should be able to aquire one at U pull it no worries Quote
trav_555 Posted March 26, 2009 Report Posted March 26, 2009 what is the difference between ae71 auto tailshaft and an ae71 manual tailshaft? is it just the end that connects to gearbox? like the little peice that sits partway in the gearbox? next to i think its called the uni joints?? could be wrong cheers Travis Quote
heathrow Posted March 26, 2009 Report Posted March 26, 2009 hey mate i looked into 86 wen i did my conversion seemed like a fair muck around so i waited a while just sussin every wreckr around till i found an ae71 manual box and it seriously took me about 10 minutes to put in so if u have time id say shop around.. Quote
SLW42 Posted March 26, 2009 Report Posted March 26, 2009 when i did my manual conversion in my ae71 i used a ke peddal box and i had to pull half the dash apart so it aint a 10 minute job!!! Quote
toyota_ae71 Posted March 26, 2009 Report Posted March 26, 2009 agreed, just put my ae71 pedal box in my ke70 last weekend... have to pull cluster surrounds out, cluster all the steering column plastics and i had to drop the steering column to get mine out!! all up it took about 3 hours!! but yeah get an ae71 setup mate would save alot of time Quote
Ae71Rola Posted March 26, 2009 Author Report Posted March 26, 2009 thanks guys... definately gonna get a ae71 set up now... gonna try and source one! and all the bits i may need Quote
