punchy111 Posted March 25, 2009 Report Posted March 25, 2009 I'm wanting to convert my 2speed toyoglide 3k engine to a manual. would i be able to use a 4k peddle box and also a 4k 5 speed box? thanks. punchy Quote
AJC Posted March 25, 2009 Report Posted March 25, 2009 (edited) If the 5spd is still cable, can't see why not. Edited March 25, 2009 by AJC Quote
Redwarf Posted March 25, 2009 Report Posted March 25, 2009 If you're talking aout using a KE30 pedal assy in a KE20, it's not going to happen. Quote
silverra23 Posted March 25, 2009 Report Posted March 25, 2009 You will need the pedal box from the same series car as what you have unfortunately. The gearbox will be easy in comparison :) Quote
Tally Posted March 26, 2009 Report Posted March 26, 2009 so what that means you will need a E2# pedal box... just look for someone wrecking a KE20... Quote
punchy111 Posted March 26, 2009 Author Report Posted March 26, 2009 also. what parts will i actually need to convert it to manual? just a peddle and gearbox? Quote
SLO-030 Posted March 26, 2009 Report Posted March 26, 2009 maybe you might have to mod your crossmember or swap it for a manual one. I think theres a write up in the FAQ :( Quote
