My engine is getting fuel in the oil ! I have changed the oil and put a new fuel pump on(last week) .BUT Bugger me ,i checked it today
and the same thing has happened ****Whats going ON
If it is fuel, I would be suspecting the new pump, did you fit the thick spacer between the block and pump.
yeah that was my first thought....it was a new one, then it put my spare on that was good as well !
it smells just like fuel
No milky oil (running strong coolant)
Do a compression test on all 4 pots, remove the filler cap and check for blow bye.
@ idle there is blow bye but @2,000rpm it stops....But found the Problem ,my K&N air filter is pressing down on the dump valve and the pressure in the fuel line is leaking into the pistions, then down to the sump
