xjaxsonx Posted March 24, 2009 Author Report Posted March 24, 2009 (edited) this is everything i can buy in a ca18, turbo kit. theres kits are from $850-$1,500 or could i get it cheaper buying it individually :P T25/T28 Turbocharger!! Turbine Turbocharger Oil cooled and water cooled Compressor Specs : 1.70" Compressor Inlet 1.685" or 42.81mm inducer 2.362" or 60.00mm Major Compressor .80 A.R. M24 T2 Compressor Housing Turbine Specs : 1.850" Exducer Turbine .86 A.R. 2.090" or 53.10mm Major 1.820" or 46.25mm Minor Exhaust Outlet Flange with 5 bolt design Comes with internal wastegate set around 7psi. Suggested for 1.6L to 2.0L engine up to 100-275HP T25/T28 Turbo Oil Feed Line !! Made Out of High Quality Aluminum Improves Engine Oil Cooling for all Engine types Length : 36" 1/8" Adapter NPT Male Fitting for the Block Comes with 90 Degree flared fitting to fit with t25 and GT series turbochargers Comes with 4 way adapter that has a removable plug (for vtec or auxillary oil feed or sensor). JDM Manual Turbo Boost Controller !! In order avoid replacing wastegate springs, which only give a fixed increase, which is not adjustable, a boost controller will be the most cost effective solution Allows adjustable boost psi settings, light weight design to be mount under the hood. Hardware is included Universal fitment and great for all Turbo applications Easy to adjust from 1-30PSI Professional Installation required Type-RS Style Blow Off Valve and Adapter Pipe!! Direct Bolt-On For All Turbo Application With Flange Universal Fitting Kit This Blow Off Valves Are Easily Adjustable To Prevent Both Premature Boost Leakage And Compressor Surge Both Premature Boost Leakage And Compressor Surge. It Can Hold Up To 1200HP Or 25 PSI Of Boost Pressure Professional Install Suggested JDM'S CA18 Stainless Steel Turbo Manifold !! Stainless Steel Turbo Manifold Higher Resistance to Heat Fits with T25 Type Turbos Direct Bolt on Manifold Professional Installation Highly Recommended. JDM'S CA18 Bolt on Turbo Piping Kit Intercooler Piping are CNC Machine Mandrel Bent (Jp Design) Made From High Quality 6061 Aluminum Material Extra Thick Piping and Increased Air Flow Light weight design. Made from Aluminum.(Increase 10-20 HP). PSi Drop under 0.2. Other Intercooler usually drop 10Psi Some are More Comes with various Turbo Pipes, T-Bolt clamps, Couplers Direct bolt on JDM'S 28 "x7"x2.5" Turbo Intercooler Tube & Fin Design Light weight designed. Made of Aluminum.(Increase 10-20 HP). All TIG Welded 6061 Aluminum PSi Drop under 0.2. Other Intercooler usually drop 10Psi Some are More Max PSi is 30 Up to 400HP Core Size: 21"x7"x2.5" JDM'S 2" Turbo Boost Gauge & Air/Fuel Gauge 52mm diameter = 2inch universal fitments Luxury Chrome trims framing Dark Tinted face for stealth JDM looks. LED lightings allow great visibility during day and night 12v gauge, light weight abs plastic finish Features White numbering and Red needles JDM'S T25/T28 Turbo Downpipe Elbow Made out of High quality of Aluminium Material Made from 100% SUS T-304 Stainless Steel 5 bolt Flange which direct fits onto t25/t28 turbochargers. link to items here:ebay Edited March 24, 2009 by xjaxsonx Quote
xjaxsonx Posted March 24, 2009 Author Report Posted March 24, 2009 (edited) then all i should need after that is loom, Ecu and rev limiter and manifold depending what kit i get and were it cheaper to get kit or individually Edited March 24, 2009 by xjaxsonx Quote
