mattman Posted March 19, 2009 Report Posted March 19, 2009 hey guys new to the forum just wondering if this has been done before can you please help me ? :D Quote
furryfrog Posted March 19, 2009 Report Posted March 19, 2009 the engine been from the same family as the ca18de i imagine it would be a similar process, but ive gotta ask why? a ca18de would be cheap and i imagine a better motor. Quote
beerhead Posted March 19, 2009 Report Posted March 19, 2009 It's probably because he has the motor already. They're a twin spark motor and my mate's old gazelle had a fair bit of poke. Being a brother of the CA18DET which is used a fair bit in old corolla's, it'll bolt in with custom gearbox and crossmember mods/mounts. Then down the track if you feel the need a CA18DET would drop right in its place. Quote
Hiro Protagonist Posted March 19, 2009 Report Posted March 19, 2009 It's probably because he has the motor already. They're a twin spark motor and my mate's old gazelle had a fair bit of poke. Being a brother of the CA18DET which is used a fair bit in old corolla's, it'll bolt in with custom gearbox and crossmember mods/mounts. Then down the track if you feel the need a CA18DET would drop right in its place. Or do what Candellan did on Twincam and make a CA20DET, but if you follow his process it took upwards of 2 years to finish... Quote
mattman Posted March 20, 2009 Author Report Posted March 20, 2009 ok thanks guys yaeh ive got the engine sitting there just thought id see if it fits and if was going to be worth while. Would i need to change much else to do the conversion other than the gearbox mounts and crossmember and could i just use the pintaras ecu its got already to run it all? cheers for the help thanks in advance. :y: Quote
