Jimpoole Posted March 15, 2009 Report Posted March 15, 2009 Hi guys. When I corner in my 79' KE55 coupe, I can sometimes hear a clunking noise. Usually when I take a left-hand corner. Also, sometimes squeeks when taking a right. Do I need to tighten or modify anything? That's about it Thanks guys Quote
JiP Posted March 15, 2009 Report Posted March 15, 2009 I've always found when I've had the clunking noise its turnout being a pitman arm or tie rod or something. Might wanna check that out. I find my car makes a continuous squeak when I turn corners. Maybe the box. Still works fine tho. Maybe take it to a steering and suspension place to be inspected?? Quote
Jimpoole Posted March 15, 2009 Author Report Posted March 15, 2009 JiP said: I've always found when I've had the clunking noise its turnout being a pitman arm or tie rod or something. Might wanna check that out. I find my car makes a continuous squeak when I turn corners. Maybe the box. Still works fine tho. Maybe take it to a steering and suspension place to be inspected?? Looks like i'll have to do some research. I would take it to a steering place if I could afford it! Thanks for your help! Quote
towe001 Posted March 21, 2009 Report Posted March 21, 2009 Jack the car up place it on chassis stands, crawl under the car and get someone to fiddle with the steering wheel while your watching the joints etc. Be a bit harder might even have better results is to do the same thing get someone to fiddle the steering wheel while your poking around the front wheels looking and feeling the joints etc.. JiP's continuous squeaking could very well be a lack of lubrication Quote
Jimpoole Posted March 21, 2009 Author Report Posted March 21, 2009 towe001 said: Jack the car up place it on chassis stands, crawl under the car and get someone to fiddle with the steering wheel while your watching the joints etc. Be a bit harder might even have better results is to do the same thing get someone to fiddle the steering wheel while your poking around the front wheels looking and feeling the joints etc.. JiP's continuous squeaking could very well be a lack of lubrication Ok will do. The noises are only really under heavy load. They don't really annoy me, I just want to know nothing's going to snap on me. I've noticed I have a continuous squeeking as well. That's annoying, and is probably going to wear something out. Do I need to lubricate the front wheel bearings while I'm at it? Quote
towe001 Posted March 22, 2009 Report Posted March 22, 2009 But have a look see first off. You should be able to figure out what you think is ok and what's a little "odd" - a typical joint operates in fairly the same fashion no matter where its located. Try with giving the joints a bit of fresh grease. If you can A continuous squeaking would be more like a suspension part thats ran dry with lube or the springs have worn out the rubber pads and are now sliding against their seats. A noise more akin to grinding would be closer to dry running wheel bearings or their running with a build up of grit. Which is not good either way. But all in all while your re-packing the joints may as well do the wheel bearings at the same time. But you'd only really be able to re-pack the joints if they have grease nipples. Quote
D1doony Posted March 22, 2009 Report Posted March 22, 2009 most places do free inspections in the hope that you get the work done at there workshop, take advantage of this... Quote
Jimpoole Posted March 28, 2009 Author Report Posted March 28, 2009 Ok, so today I attempted to tighten the wheel nuts because the wheels are loose as. Has anyone done this? How tight does the nut have to be? It seems if I just tighten until it contacts, then turning it about 1/64th either way has an effect on the bearings and they will bind. Any suggestions? Quote
