No.... MM is right, he does have MK2r's.... those you just pictured are MK2's.... notice the R in the first lot :D
Well corrected sir. Either way, sick wheels.
Mungi Mods (Terry) has been around a while, he certainly knows his wheels. Hes what you might call a wheel pimp. :cool:
  • Replies 116
Pics
powdercoated centres in "bright white " 1 day turn around and $60 for sandblast and powdercoat ...good value
slight front and rear flarage needed to fit nicely ... approx 10 mm front and 50mm rear...
front meshie on the rear
yes they are SSR mk 2 r "r" the second "r " is for RACE ( ie extreme lightweight)
I like my wheels and try to find some nice ones then when i get sick of em i sell em and get some more
Edited by mungi mods
Flare job started today with 1 inch "tub" job thrown in for good measure...
Ghetto Backyarder styles ... please no flaming..
need to make some more on car adjustable trailing arms... a job for tomorrow
have lots of pics will do a tech article if anyone is interested...
obviously not even close to finished but you get the idea
not HAPPY Jan.
broke the F#*KING welder
oh well gaffer tape for the win
car is back in daily driver mode
hope the fuzz don't see me !!!!!!!!!!!!!
Spewin!
Ah well, put your invisibility sunglasses on.
Looking pretty cool. Did you get all the clearance you need out of it?
well done and i like how you flared the rear wheel arches :D
i don't like bolt ons etc because it limits suspension travel unless you run insane stretch...
will be running 15 x 8.5-9.9 rims with a minimum of a 225/50 so need travel
most of my work takes place out of sight inside the wheel arch
you will definitely know the guards are flared when it's finished though
as you can see in pics diff is hard on the chassis rails meaning full suspension travel.. only place to set your flares from IMO try to retain as much of the factory look to attract less attention although the rims will probably attract plenty
will be adding a lip around the arch ( about 1 inch to give the affect of the car being lower than it actually is
i did these ages ago
and the owner fitted 15 x10 -6 superlights with 205/50 under them
made these on car adjustable panhard rods and trailing arms for same car
inside the wheel wells ....gain an inch without any visibility on the out side
new Daily rims n tyres
reppin' the mesh Bro'
specs are
front
SSR Reverse Mesh
15 x 7 +11 with 185/55 15 eagles ( 2.5 inches of flat Dish )
Rears are
Work Ewing Mesh
16 x 8 +11with 205/50/15 Dunlop Formula r semi slicks # inches of flat Dish )
imo it looks FAT !!!
all under rolled lip guards............WIN !!!
Pics ( sorry for quality taken just now and it's dark out )
got some new rollaclub sticker todayu
Thanks JiP...
on a side note stupid people at tyre shops...
my front SSR's should have 90 degree valves but some rocket scientist decided to put short straight ones in..
there behind the mesh so ... to inflate tyres you first have to remove rims....
will be fixed tomorrow
drives so much nicer on these rims... +1 for JDM spec rimmmmzzzzz
loveeee the ssr meshies top stuff !!!
can never have to much dish :lolcry:
you sir, are an artist
Edited by dbr11k
