  Medicine_Man said:
Make sure you use spring compressors unless you want the strut top to rip through your head and take it clean off..
You will need a rattle gun to undo it..
yes using spring compressors :P
don't have a rattle gun, il have to give the multigrips a go
done this soooo many times, you DO NOT need a rattle gun.
Firstly mount the spring compressors opposite each other on the spring,
Then put the strut into the vice horizontily and firmly put the vicegrips on to the strut top.
Get somone to hold the vice grips or if your vice isn't too high lean them up againt the table that the vice is mounted to.
Then get your trusty breaker bar or ratchet with about a meter of exhaust tube or something for extra leverage.
Then WOLA... works for me everytime. :P
haha what a joke, ive done it a dozen times without using spring compressors. The top hat hardly pops off the top when undone.
If the strut is out the car, the spring is only just captive and under hardly any pressure so it wont fly off when undone. Ive even managed to put struts back together without spring compressors.
HAHA yeah i wasted my $40 on spring compressors just to get my standards out, i replaced them with cut ef's... uncaptiveness, before anyone says anything they are in my rally car very well zipp tied in :P
got it
spring compressor's hooked up
cabletied a set of multigrips to the strut top
stood on multigrips
used my big torque wrench and a big roll of cardboard as a breaker bar :P
Edited by OniBerserker
hit another bump
steering arm doesn't want to come off
tried spraying it with wd40 then did what gregory's book said. put a support under one side of the eye and hit the other side repeatedly to break loose
but nothing... think i might need a bigger hammer
x2
if someone is asking how to do it first time, this is the right advice :)
