  • Replies 95
Lol nigel lee wah lol, stuffs me how they muckedhis name up, thats not his actual last name. Yep i was at his photo shoot for Hot4s in my green KE10, i did a skid when we left and broke and axle so we towed the 10 home with his 20 haha
awesome sample of two sweet clean little cars!!!
The 'bamboo' colored car has an automatic transmission... did I read correctly ?
Is there any information available so I can wire up/run my auto ?
what about wiring info for the S13 cluster. I'd like that in my rolla also
thanks
  oke020 said:
What did you want to know?
Hello,
isn't the auto tranny controlled by that little electronic box above the main ecu ?
are you running the entire CA18 loom - cabin & drivetrain ?
If you've isolated the tranny wiring, I was asking if there was some information available on how I could wire mine up.
Part of the body loom from that donor auto S13 was damaged, but I have the tranny/loom, silver box, main ecu & engine loom etc.
additionally
Is there wiring info available online for the S13/CA18 cluster ?
I'd like to use the S13 cluster in my CA18 starlet. I have the cluster and cut the
pigtails from the abovementioned S13.
I modified the S13 fuel pump/hanger assembly and welded the cutout on the KP fuel tank. Quiet oem operation and the nissan sending unit is ready
For my 5spd CA18 AE86, I'll attempt my NX cluster to work using this;
http://www.sr20forum.com/technical-informa...log-digital-clu
ster-93-94-se-r-nx.html
I have a waste spark signal modify circuit that 'should' keep the single-coil tach
happy/accurate
CA18 is imported here but no factory manuals.
I pulled a full complete auto tranny S13 loom/electronics for a future project.
I suppose I can use that as a reference to figure the wiring out "the hard way" if need be
thanks for reading
