Ella Posted May 11, 2009 Author Report Posted May 11, 2009 (edited) heres a new pic of it with my mags on finally... Edit: wow thats f@$kin dark, ill get another shortly as well as some pics of the new goodies for the DX. Edited May 11, 2009 by Ella Quote
Ella Posted August 27, 2009 Author Report Posted August 27, 2009 for the benefit of my for sale threads heres how it looks now I'm gonna miss you molly :P Quote
Ella Posted November 20, 2009 Author Report Posted November 20, 2009 OK! so i guess this thread deserves a revival... This car never actually sold, between me getting stuffed about by buyers, and me just plain wanting to keep it as ive always had a soft spot for it so in the end it stayed in my posession. The poor car having suffered some sort of fail inside the motor has been sitting for quite a while and my friends and i had been joking about putting a V8 in it and entering it in the drags, burnout comps and etc, and my favorite bogan revhead festival, powercruise. Only days after the discussion i iwas browsing Ebay and came across just what i needed, a custom engine plates/mount set, custom gearbox crossmember and custom tailshaft all to suit a holden 308 into a KE70 corolla. i won this auction on ebay for the princely sum of 76 dollars. Since then i have also purchased a 308 pulled down for a rebuild and a trimatic gearbox from a early model commodore, which is the version i needed. All i need to do now to finish the engine off is buy a set of bottom end bearings, new rings and gasket kit and then of course build the bottom end. i think I'm going to pay someone to do the job however as I'm kind of over the jigsaw puzzle after building the heads (relatively simple) earlier this evening. is the tourque from this going to rip my car apart? if so what needs to be braced where and what not. seam welding perhaps? i also plan on a cage as funds permit will this in itself be enough? my other hurdle is the need to setup the rear end of the car, any suggestions here would be good. I was going to get a hilux diff at the right width and get it set up with mounts to suit the corolla, or maybe even get a commodore borg warner shortened to suit. will either of these handle the v8's grunt or not? If I'm going to this trouble i think its going to be worth setting up the rear end to grip in a serious way, whats peoples opinions on what would be the best way to go with this. does the stock ke70 setup lend itself to this sort of thing or should i look at modifying my entire rear end's setup to work better? ive heard of things like 4 links and ladder bar setups Etc but know nothing about drag car setup. Also bearing in mind i'd like to be able to still somewhat be able to drive it a bit other than ten seconds at a time as i want to be able to enter burnout competitions in it. thanks guys, hope yous like what I'm up to with it here. Luke. Quote
KETURBO25 Posted November 20, 2009 Report Posted November 20, 2009 Hey dude, that cars gonna be sick when its done. I noticed that you don't have a fan blade running off your motor? (5k) so that must meen you run a thermo fan, correct? If so could you please let me know cause I'm just about to do the same to my car and if your not gonna need it any more (v8's need v8 radiators obviously) id be keen to buy it from you. Thanks m8. Pete. :y: Quote
love ke70 Posted November 21, 2009 Report Posted November 21, 2009 mmm, i like ;) it will do its very best to twist the chassis. mainly where theres the gap between the rails, and also the join from the front rails just behind the firewall, how they overlap the floor pan rails, thats where mine decided to start opening up. if you seam weld it, and get defected, you will never get the car back on the road. ever. I'm only caging mine, weld in however, and a serious cage at that, but that should be enough, and I'm after 400 at the tyres, from a turbo motor though, so probably not as much twisting action as you will see. check out some of the PR guys cars, they stick very very well, not sure how much has been done to them. its already a 4 link + panhard setup, so not much else to go with for dragging. so stick whatever diff you want under it, 9" are cheap, well known and easy to get parts for. might ahve to run a taller tyre to keep legal ground clearance though. keep us up to date :) Quote
Ella Posted December 1, 2009 Author Report Posted December 1, 2009 hrmm ive temporarily lost net acess but pics will be up as soon as i can get something sorted. Quote
Ella Posted December 8, 2009 Author Report Posted December 8, 2009 (edited) ok, so here are the pics you guys have been waiting for, here are my Custom engine plate mounts. will need a clean up and stuff but they do the job :) They are attatched to a KE70 cross member currently, but ill probably just attatch them to the one in the car already. This rollas never gonna be late with a.... Edited December 8, 2009 by Ella Quote
Ella Posted December 8, 2009 Author Report Posted December 8, 2009 inlet manifold, 2500rpm stally, and my custom tailshaft. the box ill be using, just a standard V8 version, early commodore trimatic, i have a second one to rebuild and get shift kitted and probably transbraked too :) Quote
Ella Posted December 8, 2009 Author Report Posted December 8, 2009 various bits and pieces from the puzzle that is my bottom end of my motor and other bits there, including that spare trimatic. pistons awaiting new rings, considering new pistons as well, something a little stronger to withstand a little giggle gas (yes i truly am insane mwahahaha) does anybody know how well the stock holden rods hold up to the rigours of nitrous? also my prepped and then soda blasted then wrapped up block, and my pulled apart awaiting re-kit 750 holley. Quote
Ella Posted December 8, 2009 Author Report Posted December 8, 2009 the rest oy my various bits i got, oil pump, timing gears and chain, the main caps etc. and of course I'm stocking up early lol. this cars gonna be a certified tyre destroyer haha. Quote
