shauns ke30 Posted January 8, 2009 Report Share Posted January 8, 2009 hay guy's last week i drive my ke30 down the coast for the week (new year's) and when i got back i noticed when i pulled my oil cap of my 3k motor it was blowing white smoke and it smelled like fuel really bad this has never hapend to me before. is this bad?????? cheers shaun. Quote Link to comment Share on other sites More sharing options...
philbey Posted January 8, 2009 Report Share Posted January 8, 2009 You sure it wasn't just some water vapour? Quote Link to comment Share on other sites More sharing options...
Des Posted January 8, 2009 Report Share Posted January 8, 2009 Can the fuel pumps leak into the engine on K motors ? Quote Link to comment Share on other sites More sharing options...
philbey Posted January 8, 2009 Report Share Posted January 8, 2009 Good point, yes i suppose they can if the diaphragm tears. Id pull it out and check it ASAP. Unscrew the top half of the pump and inspect the rubber diaphragm for holes etc. You should have noticed running issues with a leaky diaphragm though, like leaning out/stalling at high revs. Quote Link to comment Share on other sites More sharing options...
Teddy Posted January 8, 2009 Report Share Posted January 8, 2009 yeah i had a fuel pump let go on me a few months ago, got 100 kms to the tank of fuel and went - woha, wtf ? Oil level was high, smelt horrid, was very thin.. lol, luckily she didnt go boooooom Quote Link to comment Share on other sites More sharing options...
philbey Posted January 8, 2009 Report Share Posted January 8, 2009 (edited) Yeh by the way shaun, yes this is bad. Don't drive it until you've determined the problem. If your motor doesn't go bang, you might do some damage thanks to the new lubrication properties of the oil haha. Edited January 8, 2009 by philbey Quote Link to comment Share on other sites More sharing options...
Trev Posted January 8, 2009 Report Share Posted January 8, 2009 Lucky it's not a diesel, It would of ran on its own vapours. Quote Link to comment Share on other sites More sharing options...
camerondownunder88 Posted January 8, 2009 Report Share Posted January 8, 2009 Ill join teddys club. Yes K motor pumps if they tear will leak into the sump...BUT Toyota put a small hole in a pumps base so if it tears fuel will leak out there. Well this shitty hole gets blocked still in the box pump comes in. I don't think I have ever seen mine unblocked attracts oily shit. So id check the oil. Mine went one day I had like no fuel in the tank (ws on way to servo) and lost fuel in carby and gone oh I'm out car was like 1km from home get home to put mower fuel in then go and noticed hey I can smell fuel and well I looked and found. So be careful don't wanna wash your motor out..LOL Cheers Cameron Quote Link to comment Share on other sites More sharing options...
curly Posted January 10, 2009 Report Share Posted January 10, 2009 can go both ways they have 2 seals 1 for oil 1 for petrol so you can fill your sump up with fuel and you can fill the fuel system up with oil. i've seen people reco a motor because of a dodgy fuel pump Quote Link to comment Share on other sites More sharing options...
shauns ke30 Posted January 10, 2009 Author Report Share Posted January 10, 2009 Good point, yes i suppose they can if the diaphragm tears. Id pull it out and check it ASAP. Unscrew the top half of the pump and inspect the rubber diaphragm for holes etc. You should have noticed running issues with a leaky diaphragm though, like leaning out/stalling at high revs. yeah when i give it abit it just splaters some time's its also idoling as 1100 rpm and i can't seem to get the idol lower (the idol skrew is all the way out) my be timeing problems! and i think I'm leaking some oil from the side of the sump under the fuel pump!!!! (but that mite be the fuel pump valve leaking) if it goes boooom then ill have to put my 5k in sooner lol cheers thanks sofar guy's. Quote Link to comment Share on other sites More sharing options...
