  • Replies 59
20V conversion...... hard???
isnt that an oxymoron?
Seriously - i could do this conversion in two weekends if i really got stuck into it.
It is literally a bolt in swap - just use the engine mounts from the 16V 4age, and it just bolts in DIRECTLY. I would probably consider this more of an "engine swap" than a proper conversion.
Edited by the witzl
Do you know what you're doing with wiring that's the question?
The mechanical side of things is piss easy. I just finished a S/T 20v -> AE95 conversion which is practically the same as an AE92 but with a 4WD gearbox.
Hardest part was grinding the block to clear the gearbox and the wiring.
I think I have a pic on my laptop of the engine mount that needed to be modded I'll try and dig it up. I used the drivers side mount of the 4afe motor and there was a knob sort of bit that had to be ground off where an extra bolt that's not needed with the 20v was.
Bottom cam gear cover needs to be modded too, I just left mine off.
I hope that's a typo and you mean wouldn't because it's not a smart move. On another forum a well respected member said:
  Quote
I remember when a dude I worked with put a 20v in his AE92. It made 80.2kw at the wheels with the 16v. With the 20v it made. . . . 80.4kw. Exactly identical power curves too.
Found the pics, the top left of the mount was ground down to clear and the bottom of the cam cover notched.
I also modified the throttle cable bracket so I could use the AE95 cable.
I'm not 100% sure but I believe the AE92 is the same in the front end...
  MYSTIK said:
all ae9x were twincam
I think he meant to say 4age, not twincam.
Also I am shit at explaining myself. I meant, taking into account the wiring, and the limited gains, and the bang for buck in comparison to a 4AGZE, is why I gave up.
  • 3 years later...
i apologise for diggin up old threads,
but can someone help me with the 20V engine wirning loom to wire up to the SX fuse box and battery..as the 20V engine loom already has a (+) Battery terminal?
also the alternator wiring up to the SX
as well as under dash harness plugging into the ECU? do those wires need modification?
