  • Replies 59
will depend on
1) if the 20v is going into a carby or efi powered ae9X
2) if you are going to use a halfcut or engine package
its a carby AE92 and ill probably be getting a half cut
well you going to need the efi tank and associated fuel lines and wiring.
then its pretty much dropping in the motor and wiring it up.
Hmm I will be doing the same thing as this guy, except i already have a 4age, and I will be using a engine package.
Help me too?
hmmm the hardest part of your conversion would be integrating the wiring of the 20v into the existing 4age loom.
Edited by MYSTIK
so my transmission and everything should bolt straight up?
the 4afc transmission is shite, so use the transmission and shafts that comes in the halfcut.
i was gonna swap the loom.. would that be easier?
possibly, but most integrate the 20v loom into the standard one just so it has a more factory look
I see you told 51MMO to swap his box, should i do the same?
some engine packages don't include the gearbox, but if you happen to score one with a box on it then by all means use the box that its on the engine, it just mean you will have a spare gearbox.
Is the C50 any weaker than the C52? - I was under the impression it was only longer in gearing
not to my knowledge but i would rather use the box that came with the engine, rather than use a the c50 on the 4afc.
plus depending on the halfcut/engine package if its a ST you may get a c56 which has a different ratios again :P
Edited by MYSTIK
Cheers. any extra things i need to buy? parts etc?
just remember to change the timing belt and water pump, that goes for both people doing the conversion. if you don't, i suggest you want to order some sticky rice and sushi with you cooked 20v's :(
Would maccas be good instead of the rice and sushi? :wink:
