shauns ke30 Posted December 28, 2008 Report Share Posted December 28, 2008 (edited) Hay guy's just a couple question's i have a 5k its in my KE36 wagon that iam scrappen soon I'm keeping the 5k motor and ke55 5 speed box. And i just want to no what kind of problems i will come across when i put the 5k and the ke55 5 speed in my 1978 ke30 ;) cheers shaun any info would be great thanks Edited December 28, 2008 by shauns ke30 Quote Link to comment Share on other sites More sharing options...
trav_555 Posted December 28, 2008 Report Share Posted December 28, 2008 auto to manual? if not i shouldnt imagine many problems, i know if you replace the 4k in a ke70 its bolt in and plug in o sohuldnt imagine too much difference going to that in yours not sure about box though ;) Quote Link to comment Share on other sites More sharing options...
67Rolla-Ken Posted December 28, 2008 Report Share Posted December 28, 2008 I wouldn't think you would have any probs. What Trav said, engine's are the same physical size, box might be a different story... Quote Link to comment Share on other sites More sharing options...
dfunkt Posted December 28, 2008 Report Share Posted December 28, 2008 if both are manual, the only problem you might encounter will be electrical. alternator plug (2 or 3 pin), distributor (elec or points), reverse lights plug (different shaped plugs). i encountered those three when swapping from a 3k with 4spd to a 5k with 5 spd. Quote Link to comment Share on other sites More sharing options...
shauns ke30 Posted January 3, 2009 Author Report Share Posted January 3, 2009 ok my car is a 3k 5 speed and I'm puting a 5k 5 speed in will the 3k parts eg dizzy,fuel pump,and all the over assesories fit on to the 5k??? cheers thanks for the info sofar. Quote Link to comment Share on other sites More sharing options...
trav_555 Posted January 3, 2009 Report Share Posted January 3, 2009 i wouldnt be putting a points dizzy on the 5k, don't you have the 5k dizzy? just leave the current 5 speed, rip out the 3k and drop in the 5k, if the 5k ran before leave it the same, though probs swap over the altenators list all stuff you want to swap over :y: Quote Link to comment Share on other sites More sharing options...
Xany Posted January 3, 2009 Report Share Posted January 3, 2009 (edited) Trav, theres no problems running a 5K on a points dizzy....mines been running on a 3K points dizzy for quite some time (mainly cause the dizzy has the weights locked in it). I think the lekky dizzy's (if it actually has one) are overrated anyway. Plus it would be easier to rip the gearbox out attached to the engine.....they can be a pain in the arse to get lined up again while putting the engine back in. With the alternators, you may find that the 3K one has an external regulator....Med man should be able to give you advice on what the best path would be to take. Edited January 3, 2009 by Xany Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted January 3, 2009 Report Share Posted January 3, 2009 yea, lining gearboxes up while they still in the car isnt the best thing. I'll be sliding the engine and gearbox in as one when i put the fresh 4k and 5spd in. Quote Link to comment Share on other sites More sharing options...
trav_555 Posted January 3, 2009 Report Share Posted January 3, 2009 yea ive just had bad experiances with my points dizzy wouldnt hold high revs i suggested the old altenator so he wouldnt have to re wire it :S its a lil bit of stuffin around getting the engine to line up but to me its easier :y: cheers Quote Link to comment Share on other sites More sharing options...
Falken_KE30 Posted January 3, 2009 Report Share Posted January 3, 2009 3k had external regulator for alternator. 4k has internal so swap them over. Or there was a write up on converting to internal regulator. don't matter what dizzy you use, as long as you don't put it in 180 degrees wrong way. I find electric ones are smoother, but if they old and worn, ive found a points one to be better. yeah pull box and motor out as one, then slide box and 5k back in as one. Electric fuel pump is easy to put in and have found a bit more reliable then a mechanical pump one. leaking gaskets on them, i have one if your interested. Quote Link to comment Share on other sites More sharing options...
Xany Posted January 3, 2009 Report Share Posted January 3, 2009 yea ive just had bad experiances with my points dizzy wouldnt hold high revs i suggested the old altenator so he wouldnt have to re wire it :S its a lil bit of stuffin around getting the engine to line up but to me its easier :y: cheers All Dizzy's are susceptible to wear..my guess is something was worn inside it. Points dizzys need a little more maintenance however i find them more reliable than the Lekky ones. For example my 3K dizzy has seen more than its share of high rpm without trouble. With the gearbox, you'd rather take out 6-7 bolts around the bellhousing and mess around with an input shaft than undo the tailshaft, crossmember and gearshifter and have it all out in one hit? Quote Link to comment Share on other sites More sharing options...
trav_555 Posted January 3, 2009 Report Share Posted January 3, 2009 yea sounds weird, but it only took me a half hour and i had the engine out, first time id ever taken an engine out too Quote Link to comment Share on other sites More sharing options...
philbey Posted January 4, 2009 Report Share Posted January 4, 2009 Taking it out is the easy bit - putting it in with the box in place is the hard bit. Definitely easier to take the lot out. 5 bolts off the crossmember, 4 bolts off the shifter housing and you avoid trying to align the spigot and input splines on in a difficult spot. In KE10s as well the drag link and crossmember are much to close to the front of the box.... I've just got my 3k Auto - 5K 5 Speed swap done in my car. No fitment issues, the Alternator I just swapped and the Dizzy was already an Elec one. (Apart from Point gapping, I still haven't seen any real bonus from the Elec one) Quote Link to comment Share on other sites More sharing options...
trav_555 Posted January 5, 2009 Report Share Posted January 5, 2009 i found puttin it in easier probs becausei didnt have the help of my mate puttin it back in mate: "dude this bolt wont undo man" me: "thats cause your doing it up man" mate: "o right, true!!" :P Quote Link to comment Share on other sites More sharing options...
camerondownunder88 Posted January 5, 2009 Report Share Posted January 5, 2009 Dizzy are a whole issue to them self..LOL A points dizzy will bolt on go with the car will need more maintenance yes but very basic very reliable. But Eleci dizzy put on go forget kinda...GT40R coils blow them up you MUST have a non resistor coil Coils with resistors run lower voltage the dizzy powers off this the 2 little wires you connect. They then run at a lower power and die seen many a dead one. So if you put a eleci dizzy in change the coil to non resistor type. Also Some eleci dizzy I have had gave more torque down low so I stripped one to find slightly different weights in the dizzy (was out a van) So I presumed the van prob has a different curve in them for more torque down low. So putting an electric dizzy n can also VERY slightly change the out put of the motor. Dizzy in a K motor can go forever on that topic. Personally id stick with points buy the Jaycar MSD kit and points wear only ever 6months due to the cam part no the spark wearing it out and then you get up to 6 sparks per fire and it is cheap. Choice, choices, choices.... FYI. I ran a 5K in a KE30 pulled it out swapped the cam dropped it into my KE15 no issues (well exhaust didnt fit but again KE1X problem and was due to bigger motor in height but I got extractors now to fix this) so you should have NO issues mate. Cameron Quote Link to comment Share on other sites More sharing options...
