Very slow day, but got a little more stuff done.
intake manifold has now been studded, and Tony is now working on the throttle setup and plumbing up the oil cooler.
I'm spent most of the day grinding, bogging and painting the new scuttle panel and also the fuel tank cut out in the boot.
So tomorrow fuel tank can be bolted in and wiring run to the pump and tank sender.
Have to weld the K&N filter housings as they are cracked, 10 years of rally does that!!
OMG :blinks:
that looks awsome great work :lolcry:
thats sounds good as with the fuel tank and it all sits nicely
see ya
jimi
Thanks guys
Well a little further forward today, the aim is to try and get the engine running within the next couple of weeks, that way we can get the head re-torqued.
Still waiting on oil cooler fittings(hence only one line on the engine at the moment)oil bypass from Toyota,Thermostat from Toyota,Cam cover rubbers,a sump bung, and fuel hose.
I finished off the wiring for the fuel pump and the starter motor.
Also welded up the cracks in the air cleaner bases.
I have no idea what Tony was doing, but it didn't look like f@$k All!!
Test fitted the extractors
Fuel pump wiring done.
Cam gears fitted
just a small update.
got the new Battery coming. at a nice price of $500 with a very large weight of 1.KG. K&N filters arrived and will be bolted up this weekend.
The plan was to video it starting up for the first time, unless it throws a leg out of bed. :lolcry:
I think it's still a couple of weeks way though, have come across a few problem that need sorted first.
I think Teddy was also going to do something for you tube on the build as well.
He might as well since his build is dormant :laff:
  On 10/8/2010 at 10:29 AM, TRD ke70 said:
:lolcry: Oh so true!!!
He came around the other night saying he was going to do some work on it.
I'll believe it when i see it.
I thought he was still in Japan?
Just a quick update.
the last of the oil cooler fittings have turned up, so that can be finished.
Degreeing of the cams is been done.
Accelerator bracket has been made and fitted.
New K&N filers are here, just waiting on the pre-filters.
And the 1kg battery has arrived, lithium-ion as well, very nice.
