Picked up a nippon denso electronic distributor ,with internal ignitor.
What i need to no is what sort of coil do i run with it,brand and numbers
would be helpful.
Also there is two wires coming out of it ,one black,and one black with orange
tracer on it :dance: .
Thanks inadvance rob :dance:
hey mate if you search electronic dizzy hepza info will come up but the black/orange goes to the positive side and the black is negative.. Some of the other boys use a coil made by the "Scorcher" brand.. I just used my standard one as it came factory. cheers..
oh and sorry if iv screwed this up I'm new and its my first post but have been the quiet watcher for awhile now :)
Thanks ,yes i have looked but can't seem to find out if i still use the original coil with resistor
or not?
What i seen that original one is not correct . :)
Thinking of getting one off some think that has electic dizzy in it like a old corona or simalar.
Thanks for the head up on the wires and welcome to rollaclub
rob :y:
hey mate, i just fitted my external ignited dizzy to my 4k
what you need is a high energy coil, just go to a wreckers and grab one
i have a nippon denso, its black with green writing and came out of an ra60 celica
just connect the wires to it
check in the faq, there a few things in there about it
under dizzy in it and also under the 4ac electronic dizzy section in the faq, thats the way i wired mine up
hope that helps
Travis
