cosmetic body changes mainly a dash upgrade, Air cond as an option, Australian content import tax laws saw a lot of Australian parts used, Borg-warner diffs, Bosch alternators and holden trimatic auto's
Oh god do I have to explain again... You would find it if you did a search but anyway...
Engine upgrade, 3K to 4K, intrusion bars in doors (Car now heavier hence engine increase), bonnet change, grill change, rear demister now standard, foam door handles now standard, material used in cloth seats changed, design overall with seats changed -now comfier and has a knob to adjust ,bumpers changed, rims changed,braking system was upgraded, center console now standard, diff change, rear vent changed, chrome mud flaps on front guards now gone, steering wheel changed,
There could be more but I'm tired.
How are the rims different? They look the same to me :jamie:
If you look closely the KE30 ones are a thinner rim and the hole in the center is almost like a tunnel. About 2cms.
^^^ this man is correct. they changed centre caps also. the early ones have clips that grab onto the centre tunnel, the late ones press on and just "hug" the centre tunnel.
i have pics if necessary to show the centre hub difference.
dF
