Talking to Charity Rolla about this and was wondering if there were any control arms that could be swapped into a ke30 for a bit more camber? are there any struts that swap over easily that could possible improve handling at all?
Also, would it be possible to fit rack and pinion steering out of a kesev into a ke30?
CHEERS
Ryan
Edited by SLO-030
Ive seen a KE70 rack grafted into a TA22 celica, The guy just copied the KE70 cross member to make mounts on the TA22 cross member and made an extender for the existing steering shaft.
Sigma lower control arms.
these are from a GH sigma with press in ball joint. these arms give a 60mm total track increase and close to -5 degrees camber. obvious disadvantages are increased inner edge tyre wear, straight lone braking can also be comprimised due to less of the tyre being in contact with the road. these arms have to be used with RA40 celicas tie rod ends to ensure the correct toe setting can be reached. cost depends on wrecker, but you should be able to get the parts you need for around the $100 mark. requires some modification to inner arm bush to fit, (grind a bit of the steel tube section down, so it fits betwwen subframe)
quoted from 86dc, talking about putting them into a ke70/ae86
because ke30's have longer lca's than ke70's the camber that sigmas give will nto be as extreme, my guess is about 3 degrees each side, which is still a fair bit however if the car is to be driven on street, accelerated tyre wear and other things mentioned above.
Is there enough meat in the cross member to relocate the pivot points. Was able to move out the pivot points on my KE20 about 25mm to give extra camber.
why not just get cambertops?
Well, up until about 2hrs ago i had no clue as to what camber tops were (thanks Alex)
Suspension really isnt my forte.
Thinking about just leaving it all stock for now and getting the mods done that I'm in the proccess of doing.
Then i can think about toying with struts and camber.
Might keep researching the rack and pinion conversion tho.
sigma lcas also give ya more track man :jamie:
I'm doing the suspension in my ke70 now man, i can send you photos and shit and info just ask, and also look in the faq as they have stuff about suspension, and stuff about what you have to do to the sigma lcas too
Travis
when Iwas doing my 55
was told to use RA 60 celica front struts complete and T-18 lower control arms to get things back into line
never got round to doing it but the guy who told/showed me had his done like that for his 2TG engine add
later
P
later
P
Who was that guy? I'm interested in doing the same front end conversion.
