Ok
I have just bought lowered springs for my AE71, two inches all round. I am wanting to replace the shocks at the same time to save work.
Apparently not many (or none) places make shocks for AE71.
There must be another Toyota alternative.
Does anyone know which ones I buy and if I have to modify anything what do I need to do??
PS. I do not wish to replace whole strut assemblies etc as I already have the springs etc. I bought them brand new so changing them over is not feasible.
Yep, there's no decent shock absorbers that will fit in an AE71 strut, thats why most people opt for an AE86 or a corona strut which take the 50mm diam shocks, and give you heaps of selection. For the rear most run commodore wagon shocks. Just have a search through a few threads in the projects section, I bet you'll find what you need to know.
for the rear ive usede both ra60 rear shocks and HQ rear shocks
both monroe gas, and both were quite effective.
shorter stroke to suit lowness and from heavier cars so are stiffer,
havnt driven much on the HQ's but the old ra60 you pull it over the fence specials i ran in my old car were amazing lol
  • 5 weeks later...
hey all i own avery low 71 with 18s on it... there isnt much room left as you can imagine :yak:
but i was wondering, are ae86 struts in some way "thinner" than the standard ae71's?
if your looking for a "thinner" set-up look at doing a coilover conversion on your struts. Coilover springs use a smaller diameter spring which therefore have more clearance
yes i was going to buy a set of decent coilovers anyways but i wasnt sure weather i could get away with just the 86 struts, so there is no difference?
Edited by dbr11k
A possible option for standard AE71 struts by way of a shorter stroke shock is
VOLKSWAGEN - Golf (Series I & III), Convertible 79-93 Front
VOLKSWAGEN - Golf (Series I), Hatchback 73-8/83 Front
According to the Monroe catalogue they share the same body diameter but about 60mm shorter in stroke. Not the most ideal though as I doubt they'd be any/much stiffer than stock ones.
