theres one particular model of 4afe thats very simular to that of the 7afe, that one will fit without too much of a hastle, probably even with all the 7afe electrics. "Holden" Novas had them too
the 7afe turbo motor only made 115kw. alternatively you could swap in a smallport ae92 100kw motor a lot cheaper if you use the stock 4age ECU.
sorry my bad- standard 4 age wont fit
need to use an AFE motor for the engine block cut out so the 4WD drive system as the car is an AE95R
115 KW will be great compared to the SFA I have from a 350Klm tired 4AFE
later
P
Edited by ogre6br
