Yeh had noticed the damaged screw. not worried because these come in the kit. Will definately be cleaning thoroughly.
Make sure both venturi,s are the same size, also be carefull not to swap venturi tubes with a standard carby as singles will be slightly larger and you will develop a flat spot.
Edited by KE30_KE35_KE55
Never had an issue running two "single" carbies instead of the proper 3KB ones, if that makes sense.
The main thing is that they are the same so its balanced for tuning, the larger venturi could cause a flat spot depends how you drive it too.
Sounds like I owe you a prize... my gratitude good enough for you? :'(
Yep thats fine. Just the satisfaction of someone using these for "originality" is good enough for me. There not a high performance carburettor but factory go-fast parts look cool.
