hey . this is for a friend. he owns a car as the same model as the one in the pic and its a 4a-c auto and it keeps blowing head gaskets (5 to recall). i was thinking it was something to do with the way the radiatior was mounted and was making air pockets in the top coolent cilinder in the engine? could be wrong please help
If it blows the head gasket your also ment to try and find out why it blew. Most cases its from over heating so get the radiator professionally check, replace the water pump and thermostat. Flush the whole system with the heater on. If a 4ac does a head gasket it is cheaper to buy a 2nd hand engine from a wreckers and put it in.
