trav_555 Posted November 30, 2008 Report Posted November 30, 2008 ok well my worked 4k with an unknown cam and high compression and extractors and exhaust is not running right, i needed him to do a service and set valve clearances but now it gets all jumpy and weird after 4000 rpm, and dosent make as much power as it did before i got the service any ideas? Quote
PMP020 Posted November 30, 2008 Report Posted November 30, 2008 if all the mechanic has done is oil and filter change and tappet adjustment. highly possible he has incorrectly set the tappet adjust. if you payed for this to be done i wouldnt bother mucking around with it and take it striaght back and get them 2 sort it. cheers, scott Quote
trav_555 Posted November 30, 2008 Author Report Posted November 30, 2008 yea i will be tomrow, he said he also fixed some vacuum leak or something, though i don't remeber there being any vacuum leaks, and also he said i don't have all the bolts in my intake on and I'm like well i can't get to em cause of extractors now aye but yea will take it back to him cheers Quote
trav_555 Posted November 30, 2008 Author Report Posted November 30, 2008 is it called valve bouncing, cause it just feels like the revs are jumping around when it gets high rpm. and i used to feel the cam kick in around then also car konks out when i change to a lower gear and push clutch just goes down and dies, *** annoying cause it makes it look like i stall it... Quote
seabiscuit Posted November 30, 2008 Report Posted November 30, 2008 (edited) is it called valve bouncing, cause it just feels like the revs are jumping around when it gets high rpm. and i used to feel the cam kick in around then Valve bouncing is when you are reving the $%#T out of the car and it doesn't fire properly, I believe. also car konks out when i change to a lower gear and push clutch just goes down and dies, *** annoying cause it makes it look like i stall it... Yea, I have this problem occasionally and people laugh because they think I stall :(. If he was playing around with that "vacuum" leak, which was most-likely to do with the carby, something may have gotten in there, like a bit of dirt and is blocking something. What this guy did from NRMA to try and backfire the "shit" out of my carby when I called them up about this problem, was cross over TWO of the spark plug leads and then started the car. He revved it to about 3-4k let it die down to almost a stall and then put his foot flat to the floor until it backfired. This backfires the system and supposedly gets some of the shit and corruption out of the carby, which could be causing a blockage. My carby has a vacuum problem and only 1 of the jets works. I'll hopefully be getting a Weber soon though :hmm: Just get the mechanic to fix it until it's right, so you don't have to piss around with it anyway :dance: Afterall, he farked it up! EDIT: MAKE SURE YOU DO WHAT OniBerserker SAYS! Edited December 1, 2008 by seabiscuit Quote
OniBerserker Posted November 30, 2008 Report Posted November 30, 2008 What this guy did from NRMA to try and backfire the "shit" out of my carby when I called them up about this problem, was cross over TWO of thespark plug leads and then started the car. He revved it to about 3-4k let it die down to almost a stall and then put his foot flat to the floor until it backfired. This backfires the system and supposedly gets some of the shit and corruption out of the carby, which could be causing a blockage take the air filter assembly off before you do this shoots a nice jet of cleansing fire out the carby Quote
Taz_Rx Posted December 1, 2008 Report Posted December 1, 2008 take the air filter assembly off before you do thisshoots a nice jet of cleansing fire out the carby Sounds like a lazy mechanic to me!!!! :dance: So rather than spending an hour to pull the carby apart and give it a good clean, he would rather put your timing out by 180o and possibly do worse damage to the engine!! :hmm: Intellegent. Quote
DearmanKE Posted December 2, 2008 Report Posted December 2, 2008 thats what i was thinking, but i spose with a relatively stock motor you wouldnt be able to do too much damage...with boost however Quote
trav_555 Posted December 2, 2008 Author Report Posted December 2, 2008 well i should have the elec dizzy in this weekend i hope as ke ping it real is sending me his ignitor (cheers) so that should get rid of any points bouncing that the mechanic is blaming it on yeah well i was revving the darn out of it lol and i used to and it didnt do that, makes a weird noise wher like jumpy air out of exhaust, like a turbo kinda thing, but massive power loss yea, two bolts on manifoldsre not on I'm trying to get them on, but engines hot so gonna do it tomorow wish i had the cash id get me some efi goodness cheers Quote
irokin Posted December 2, 2008 Report Posted December 2, 2008 Sounds like he f@$ked up the valve clearances to me... or hes exacerbated an existing problem in your engine. Quote
trav_555 Posted December 3, 2008 Author Report Posted December 3, 2008 thats what i reckon but i doubt he will admit it got bill for it today, 163 bucks..... he better not charge me extra to make it run at least as good as it was before hopefully the ignitor will be here soon so i can finally chuck the elec dizzy in, then he can't blame points cheers Quote
KE ping it real Posted December 3, 2008 Report Posted December 3, 2008 Hey Trav Mailed it to you today so hopefully you get it by friday Quote
trav_555 Posted December 4, 2008 Author Report Posted December 4, 2008 Hey Trav Mailed it to you today so hopefully you get it by friday sweet thanks heaps man, hopefully i do, but our towns mail is shitehouse when its on i can blame valves like i did in first place :yes: Quote
trav_555 Posted December 5, 2008 Author Report Posted December 5, 2008 didnt get here today... hopefully monday, stupid aussie post :yes: headlights got here today they, they worked out sweet, makes front end look brand new! Travis Quote
rob83ke70 Posted December 5, 2008 Report Posted December 5, 2008 I'm a motor mechanic. I'm going to offer my two cents, that the valve clearances were not set right. I have a reground cam in my 4k in the ke55, and if i set it to stock clearances i lose all compression when cranking, its hard to start and it produces a lot less power, but if set to what the cam manufacturer reccommends then the compression comes right up (along with audible valve noise) and it runs quite well. stock clearances i think are 0.20mm inlet and 0.25mm exhaust. I think mine are set at 0.35mm inlet and 0.40mm exhaust. Have to be carefuel that its on the very most bottom part of the base circle of the cam lobe when setting them too. These figures are for a warm/hot engine... I hope you took it to a general mechanical workshop not a dealership.... valve clearances and old cars are a bit of a lost cause with younger motor mechanics these days like what you would find at dealerships. You have to find a mechanic thats been in the trade a while, and that is really into cars especially old school performance mods and so on. It is difficult to find a mechanic that is really good, but they are out there. The number of motor mechanics that I would let work on my own cars I could count on one hand.... and I'm in the trade!! Robert. Quote
