coln72 Posted August 23, 2005 Report Posted August 23, 2005 Kanga, you have heard mine run in a motorkhana. Its running hydrolics and I think it revs out OK. Quite often have the shift light on for the entire run (set at 7500 rpm) Quote
Super Jamie Posted August 23, 2005 Report Posted August 23, 2005 i've never hit any valve bounce from my engine (single valve springs) and its been in the car for over a year now with little problems i also think dual springs are overkill on a K engine. i'm running hd singles and they've been fine :thumbsup: Quote
ROLLN'03 Posted August 24, 2005 Author Report Posted August 24, 2005 I'm yet to see how my hydro's will go...... If they are not what the doctor proscribed ill be switched...... Trial 'n' Error.... :thumbsup: * Great Discussion Quote
Mr Revhead[RL] Posted August 24, 2005 Report Posted August 24, 2005 stock valve springs are k series rev limiters :thumbsup: Quote
cookie Posted August 24, 2005 Report Posted August 24, 2005 hmm, i don't remember whose it was. a quick burst to 7500 isn't the problem, it's holding it there, letting the lifters pump up i used to take my 4k to 8500 all the time =) i'd just say to people "watch the tacho" and launch in 1st, wind off the dial, then do the same in second, by then we'd be doing just under 100km/h Super Jamie how did u manage to get 8.5K rpm always :thumbsup: were u using standard single carb or weber or SU carb :wootjump: Quote
mikeys toy[RL] Posted August 24, 2005 Report Posted August 24, 2005 i take it 4k lifters are different from 5k? all the listeings here are for 3k (4/69-?/79) and 4k are the same Quote
Xany Posted August 24, 2005 Report Posted August 24, 2005 (edited) btw: after the last bit of headwork to my 3K bigport it now has holden 202 valve springs.....i havent had a problem with them yet.... :thumbsup: remember nick, you have to get the valve spring seat machined out to accept the holden springs. Edited August 24, 2005 by Xany Quote
Felix Posted August 24, 2005 Report Posted August 24, 2005 most cam manufacturers recommend if using double valve springs, to run in the cam using just the outer springs. you should add the inner springs only AFTER the cam has been properly run in. Quote
Felix Posted August 24, 2005 Report Posted August 24, 2005 my 5k runs double valve springs, actually, the inner spring is more a damper type spring. they came from petes old race car. think they are some sort of aftermarket holden spring. it would operate over 8 grand most of the time when they were doing motorkhanas, it had a 30/70 cam, and the same lifter setup i now run. i have had my 5k well over 8 grand, but there is not much point. the cam (tighe 113 25/65) gives faster acceleration if i change at 7 grand, and let the torque in the next gear do the work. note the same cam would make power to 8 grand when it was in my previous 4k, and come on cam about a thousand revs later. i raised the rev limiter in the 4k (LOL), by shimming the stocky valve springs until there was 10 thou between coils at full lift. at motorkhanas i would often just hold it flat and let the thing valve float continuously. had quite a few people come up and ask me if i had ever heard of a rev limiter. :thumbsup: Quote
Super Jamie Posted August 24, 2005 Report Posted August 24, 2005 Super Jamie how did u manage to get 8.5K rpm always :thumbsup: were u using standard single carb or weber or SU carb =) hold my right foot down and not change gears my engine pulls 8500 with the modified single aisan i was using at first, and i've had it there with the twin SUs i upgraded to later Quote
mikeys toy[RL] Posted August 24, 2005 Report Posted August 24, 2005 4ke computer has a rev limiter @ 6,500rpm Quote
cookie Posted August 25, 2005 Report Posted August 25, 2005 Super Jamie how did u manage to get 8.5K rpm always :thumbsup: were u using standard single carb or weber or SU carb :drinks: hold my right foot down and not change gears my engine pulls 8500 with the modified single aisan i was using at first, and i've had it there with the twin SUs i upgraded to later cool man :wootjump: need to learn how you modify the asian carb =) Quote
