well it seems my car has a miss.
I have a ke30 with a 2tc engine
recently replaced the distributor cap/ rotor and points along with the spark plugs and cables, the carb is set to the factory specs there is no vaccum leak either, timing has been checked as well.
It occurs when staying a constant speed
when accelerating it does fine and seems to dissappear
any ideas?
thanks, matthew
shit does of fuel?
Sounds like you have the bases covered for everything else (igntion, timing etc etc)
Other then the miss at constant speed, does it drive fine? ie. accelerate fine, or is it sluggish?
Bit of shit in the carby? give it a good whack with some carby cleaner and see how it goes.
without knowing the exact situation (and being limited with early corolla stuff) its hard to say whats causing it.
Dodgy coil?
