Matthew146 Posted November 22, 2008 Report Posted November 22, 2008 well it seems my car has a miss. I have a ke30 with a 2tc engine recently replaced the distributor cap/ rotor and points along with the spark plugs and cables, the carb is set to the factory specs there is no vaccum leak either, timing has been checked as well. It occurs when staying a constant speed when accelerating it does fine and seems to dissappear any ideas? thanks, matthew Quote
orangeLJ Posted November 23, 2008 Report Posted November 23, 2008 shit does of fuel? Sounds like you have the bases covered for everything else (igntion, timing etc etc) Other then the miss at constant speed, does it drive fine? ie. accelerate fine, or is it sluggish? Bit of shit in the carby? give it a good whack with some carby cleaner and see how it goes. without knowing the exact situation (and being limited with early corolla stuff) its hard to say whats causing it. Dodgy coil? Quote
Matthew146 Posted November 24, 2008 Author Report Posted November 24, 2008 today i have narrowed it down to the carb. i am either getting a rebuild kit for it or going to try to find a cheap replacement. any ideas for the later? Quote
godlovesugly Posted November 25, 2008 Report Posted November 25, 2008 ebay has weber adaptor plates, or you could make one. then just find a cheap 32/36 weber Quote
