update for ryans car
we were cruisin through the hills when ryans car started running like a truck
couldn't get it started so had to roll start it.
he didn't quite get home after boostin it back to his place so looks like we'll be seeing whats going on there tomorrow
  • Replies 611
Car is NOT running at all :cool:
I think it may be plugs and Luc thinks it might be a piston ring (worst case scenario)
Looks like a day off of work to get the rest of the new 4k bolted together and hopefully drop it in N/A
f@$k, Not my lucky weekend.
Broken ring won't stop it running, at least not until it shatters into tiny bits, jams in the piston and causes a hole down the side!
It will make a definate little clicking knock as the piston won't be held tight and will slap.
More like head gasket... or something quite serious.. :cool:
Luc thinks it might be a push rod or two that have jumped the rocker like what happend to him.
Piecing new engine together with jason as we speak (lookin for monotorque torque specs)
Didn't the torque settings come with the new head gasket?
I have an original manual, if that is any help?
A.
ahh it sucks when your half way through building your new engine and your old one craps its pants aye, happened with me had to put in the new 4k before i got it to where i wanted it, still goes hard though but now i don't have time or money to get a carby right now which is what i missed out on oing (+ more head and block work)
but yea that sucks mate, if anything it was the head gasket with mine
also you have same set as me? it comes with the torque settings on the peice of cardboard man
i also have original 4k manual if need be
later man, don't stress and don rush aye
Travis
Yea it came with the torque specs on the board, just couldnt find them :cool:
Found them in the end and the head is all torqued down tight.
yees indeedy
Got the 30 home from out front of a mates place just before sundown today. swapped the plugs for good ones out of the 4k I'm building. still running like shit.
Turns out to be the carbs leaking like FARK, especially around the accelerator pump. Oh well, kesev carb in the shed.
EDIT: Looks as if jason maybe coming round tommorow, if he does he just made $50
Edited by SLO-030
  Jason KE30 said:
stoked :P
By the way, if you need anymore help I am a bum at the moment and have nothing to do at all.
So i think you have my phone number now, give me a hoot if you want some help with shiz.
4k is all together, just have to get the water pump, dizzy, alternator, rear main and sump on.
Many thanks to Jason.
Also Jason and Doug came round while i was at work and swapped my carb for me. Runs fine now :P
