gday all....
i'm new to the 7afe engine....
what sort of mods could be useful on this engine....
i have a 2" or 2 1/4" cat back and a pod with custom piping....
also anyone got a read up on how to build a 7AGE????
cheers rhys
  • Replies 30
so you end up with 8.8:1 compression without a head skim? mmmm
lol @ "i never thought id say this but torque really is very exciting too on the street adding a whole new dimension to the corolla!"
gee, who'd have thunk it?
this guy just slapped the 4a head on to the 7a block, without changing anything else really, plus like i said it was a "rough guide".
  TheGhost said:
gday all....
You've done just about all you can without spending heaps of money.....headwork can open it up a little bit, but combined with a bigger throttle body and you'll probably need a piggy-back like an eManage to fix up the maps.
bit of lag now at bottom end of revs.... but top end goes overrated....
anything over 3500 is a nice kick compared to before....
i had one on my laser efi, hmmm!
  Jono said:
its probably your exhaust causing less backpressure at low RPM and yet flowing better at higher RPM.
well i would think a cat back 2" would cause that....
only started after pod went on hence my reasoning....
  Jono said:
pod would be sucking in warmer air than with the factory air-box setup.
Which is why you put the pod behind the front bumper where the resonator normally goes, and fashion up (ie cable tie the spashguard open) a scoop for cold air
