You and I are having the same problem man, just save up and replace everything you can.
I'm doing my timing chain this week, ignition timing and valve clearances...
My engine has been sounding like a diesel tractor too lol
  • Replies 31
i wanna pull the engine apart n find the prob but got no time and i need my car every day
il just keep going till it screws up even more + it is over heating
  ke30Rolla myles said:
<snip>
and when i try to start the car it is like there in not enough power or something is getting jammed
then it finally kicks over
That could be a bad battery, load test will tell you that.
Dirty connections or possibly a dying starter motor.
also check the voltage drop as you are cranking the motor.
Edited by furryfrog
Sounds to me like the starter. Mine had the exact same problem. Brand new battery and leads to the starter and it still had trouble kicking over a tired 4K. Replaced with a new reduction one after it failed to be able to turn the 5K and I haven't had any problems since. Grab a multimeter and do a few tests though before spending money on a new battery or starter. :P
Regarding ticking sound, if you need the car a daily and can't afford to take it off the road, best bet would be to just put up with it for the mean time and perhaps just buy another 4K in better condition from a running car. It's probably easier and cheaper to just pull the old one out if something major happens and replace it with another one over a weekend with some mates, rather than rebuild the one you have.
But like others have said, just drive it till it dies.
For the sake of a day or 2 without a car. fix the problem now, before it gets worse. When it does finally screw up you could find yourself without a car for longer. Ive seen it happen too :P
Drive till dies... i had a the timing chain rattle like a bitch for a week, thought it was going to go though cover lol.
Then all of a sudden it stop. i still redline the car most days lol.. go a rebuilt 4k in shed with a 5 speed waiting to go in when this 4k dies.. ill be waiting a while LOL
brrrrrrrrrrrrrmmmmmmmmm brmmmmmmmmmmmmmmm brrrrrrrrrrrrrrrrrrm brrrrrrrrrrrrrrrrrmmm bang bang put put brmmmmmmmmmm brrrrrrrrrm bup bup brrrrrrrrrmmmmmmmmmmm.
