rundell Posted November 10, 2008 Report Posted November 10, 2008 Ok well when i went to change my head gasket i rounded a bolt near the front near the coolant pipe and just seeing on what is the best way to get it out i was thinking grinding or fileing two flats on each side and doing it with a wrench. ANyone have any helpful ideas?? cheers rundelll Quote
Redwarf Posted November 10, 2008 Report Posted November 10, 2008 Buy a Metrinch socket. They grip on flats, not on corners. Thats what I use. Quote
rundell Posted November 10, 2008 Author Report Posted November 10, 2008 Buy a Metrinch socket. They grip on flats, not on corners. Thats what I use. Hmm any idea where to buy one of these? and is it just a socket to go on any wrench or do you ahve to get a certain set? cheers Quote
rundell Posted November 10, 2008 Author Report Posted November 10, 2008 great no tool place has those sockets :y: oh well might bring out the trusty angle grinder and cut bolt off then use pipe wrench. to get bolt out once heads off Quote
harun Posted November 10, 2008 Report Posted November 10, 2008 Try drilling a hole into the centre of the bolt than use a hammer to place an allen key in the hole.The allen key will wedge itself within the rounded hole allowing you to turn the bolt. Quote
rundell Posted November 10, 2008 Author Report Posted November 10, 2008 Try drilling a hole into the centre of the bolt than use a hammer to place an allen key in the hole.The allen key will wedge itself within the rounded hole allowing you to turn the bolt. Yeh i was gonna do that but instead use easy out screws but beacause the bolts in tight it wouldnt work or rip the tread or something Quote
rundell Posted November 10, 2008 Author Report Posted November 10, 2008 Vice grips. yeh tried that seen where the front head bolt is thoght not much clerance :bash: this is on a 4k. So far my desisions are try carefully angle grind the top off the bolt then use pipe wrench when head off to undo. Or mate came up with good idea to find a nut that will fit over it then use a socket to get it off Quote
rundell Posted November 10, 2008 Author Report Posted November 10, 2008 Or if anyone knows where to source one one of these metrinch sockets in adelaide??? Quote
Red_rocket Posted November 10, 2008 Report Posted November 10, 2008 i got a set of metrinch at Blackwoods, there is a shop on south rd at regency park just behind CBC bearings! cost about $110, Best things you will buy! 24 spanners fits 74 different size bolts i think? but they are spanners, not sockets.. not sure if you can get the metrinch sockets anymore? Quote
luke.t. Posted November 10, 2008 Report Posted November 10, 2008 Try getting a socket the next size down from the bolt size and smack it with a hammer until it fits.... Might wrk......try using a old socket or one you don't use cos it might brake :bash: Quote
ke30Rolla myles Posted November 10, 2008 Report Posted November 10, 2008 hey this hapend to me on saturday what we did was got a hammer and cement chissel n make like chunks into it so the vice grips GRIPPED then it came out easy Quote
Redwarf Posted November 10, 2008 Report Posted November 10, 2008 Someone like Blackwoods should have them. You just need a standard ratchet to ise them. I've also seen them at Bunnings, but I don't know if they stock them now.... Quote
TE278U Posted November 10, 2008 Report Posted November 10, 2008 weld a nut to the head of the bolt, filling the inside of the nut with weld. then use socket to undo nut. also tighten the surrounding bolts of the f@$ked one to relieve pressure on it. always undo head bolts in sequence, and use a six point socket (like an impact socket) where possible. -dave (boltologist) Quote
towe001 Posted November 10, 2008 Report Posted November 10, 2008 (edited) Hmm any idea where to buy one of these? and is it just a socket to go on any wrench or do you ahve to get a certain set? cheers http://www.justtools.com.au/prod3529.htm Have a look in the phonebook for a Blackwoods store http://www2.blackwoods.com.au/Default.aspx Edited November 10, 2008 by towe001 Quote
