Ratty Posted April 21, 2005 Author Report Posted April 21, 2005 dude that is looking sweet did u paint it yourself? Look forward to more pics :P Quote
TRD ke70 Posted April 21, 2005 Report Posted April 21, 2005 rjenman, spot on. Sounds like you have done your homework! Any 4a-ge can be changed to rear wheel drive, as long as you source a RWD gearbox (T50 bolt on, W50, W55, W56,W57,W58 overkill etc etc etc) 4A-GE 20 valve WILL fit into a KE35, but... there is a catch (doh) The distributor will stick into the firewall ! You will need to cut a hole, or bash the firewall into the right shape. Alternatively, use a Crank angle sensor (from 4A-GZE) Search on Google for 4A-GE 20valve AE86, same procedure, different car. the W50, W55, W56,W57,W58 gearbox, what do they come out in??? and do that use a T50 bell housing??? anyone know Quote
demuire Posted April 21, 2005 Report Posted April 21, 2005 TRD_ke70: W5x boxes mostly came out in Supra's, although I think the W50, 55 and 56 came out in the later model Celica's and Corona's. Something along those lines. W57 and W58 are apparently the ones to get, as they are alloy cased so a fair bit lighter. W boxes don't use T50 bellhousings, but you can get bellhousings to mate them to a 4AGE. The cheapest I've been able to find are from Malaysia, and will cost you approx $300 (for the bellhousing). Clutch on drivers side (like Jap spec 4AGE), starter top passenger side (like stock). You'll also need to get a clutch to suit. Quote
demuire Posted April 21, 2005 Report Posted April 21, 2005 Here's a link to some people buying some at Toymods: http://forums.toymods.org.au/index.php?t=m...480cc46bc115c16 Bill Sherwood brings them in from Malaysia. I think Anthony Kellam has recently bought 3 from Bill. Quote
PeanutBoi78 Posted May 19, 2005 Report Posted May 19, 2005 I can get u a 4K with flat tops, racing cam, webber carb and 30thou oversize. It has all the goodies. If ure interested it is one tough motor. :moon: Quote
Super Jamie Posted May 19, 2005 Report Posted May 19, 2005 we don't want to ship things from america which we can get here out of interest, what are the specs on your "racing cam"? Quote
PeanutBoi78 Posted May 19, 2005 Report Posted May 19, 2005 I'm in Qld and its my mates it think its sum think like a 65 35 cam or sumthing Quote
Ratty Posted June 6, 2005 Author Report Posted June 6, 2005 thanks dude sounds good but I'm in perth and i have a motor in mind thanks any way :) Quote
20V_KE35 Posted June 13, 2005 Report Posted June 13, 2005 just a quick one...heard someone said k40 or k50 will bolt up with 4age...true of not...if can will it stand the power of 4ag??? Quote
Super Jamie Posted June 13, 2005 Report Posted June 13, 2005 didn't you ask this somewhere else? there is a gearbox that may fit, but you'll blow it up very fast. don't bother Quote
Ratty Posted June 16, 2005 Author Report Posted June 16, 2005 Yes the T 50 gearbox would be the better than K40 or k50 i read that the T50 can handle up to 200 hp so thats not bad in a old rolla. Here is some sites worth checking out for info on gearboxs and 4AGE engines http://www.geocities.com/Colosseum/4883/ http://www.users.bigpond.com/vidore/toyota_4age_engine.htm Quote
Ratty Posted June 16, 2005 Author Report Posted June 16, 2005 Also notice the light weight of the T50 and T40 25 kgs good to get power to weight ratio up that is power up weight down lol Quote
Super Jamie Posted June 16, 2005 Report Posted June 16, 2005 lol, T50s are bloody heavy gearboxes, about the limit of what one person can carry in such an awkward-sized package. a K gearbox is so much lighter :P Quote
Ratty Posted June 16, 2005 Author Report Posted June 16, 2005 lol, T50s are bloody heavy gearboxes, about the limit of what one person can carry in such an awkward-sized package. a K gearbox is so much lighter :P Sorry i should have been more direct i meant the T50 is lighter compared to the W gearboxs but hey the W gearboxs can handle alot more power than T50 About 300+ hp as seen here....... '76-81 Celica GT W55 Supra 3.566 2.056 1.384 1.000 0.850 - 4.091 160 300+ Common 35 kg COMPARED TO T50 Split 3.587 2.022 1.384 1.000 0.861 - 3.484 124 200hp Common 25.5 kg 3K(rare), 2T, 2T-G, 3T-C, 3A, 1S,4A-C, 4A-GE Quote
Ratty Posted June 25, 2005 Author Report Posted June 25, 2005 found a good web page on the 4age http://www.users.bigpond.com/vidore/toyota_4age_engine.htm enjoy!!! Quote
