rollcage painted before install
Sparco Race seat
Carbon Fibre CAS cover
Test fitted a mates 14x10 w 265's :thumbsup: looks like a speedway car haha
Slight flair of the gaurds and you would get them under! wouldnt you? Hahaha
Nah man this thing keeps getting better and better...I love it!
Those wheels on the 20... best thing ive ever seen.
We should put all four on once i put the rims back together :thumbsup:
Yeh Paul, I'm keen. don't think the fronts will fit over my new brakes though.
haha yeh maybe.......
I am going to flair the guards slightly though to allow for bigger wheels/tyres, wrong wheel/tyre (too narrow) but offset is about what the wider wheels/tyres will be so going to try flair the guards to suit these
planned front end set-up :rolls:
S2 RX7 struts
koni adj shocks-revalved
coilover kit-8kg springs
Adj strut tops-use ones i already have
FC calipers-rebuild
EBC pads
BDA slotted FC rotors
1 inch master cylinder
braided lines
22-24mm swaybar
steering/LCA etc will also need changing/modifying to suit the struts, not looking forward to the hassles that will bring
your only running standard ports hey?
yeh standard ports, import motor. low boost=211rwkw
New set-up will be ported and more boost plus a few other little improvements
while waiting for front end parts i thought i would flare my rear guards to suit my saab rims. So ill be running a full set. These are 15x6 with 185/55/15 i have been running a 14x7 with a 205/60/14
Rims n tyres, cheers to corey for the hook up with tyres!
Notice the nanna ride height, rock solid stiff but keeping with the sleeper theme:smiley1:
as you can see they stick out the guards roughly an inch
So i tackled the rear guards with a heatgun, hammer and rubber mallet. resulting in....
This shows how much extra room i now have with the 14x7's back on it, these use to sit flush with the lip and even tho rolled scrubbed on accasions.
don't mind the cracked paint, shiny paint doesnt make it go faster. Ill get around to fixing it
The plan for down the track is to get some 15's made in the same offset/wide as the 14's and run a 225-235 rear tyres. Bit of extra grip would be nice
Havnt finished passenger side yet and will be spending some more time on the drivers side before I'm happy with it
