flat out Posted October 22, 2008 Report Posted October 22, 2008 G'day my mates car is fitter with an external waist gate, it had a 16 psi spring, but unfortunately rb30e's don't like 16 psi with a stock computer, so he has brought a 6.6? psi spring and we fitted it, it was a fraction smaller in diameter and about 2cm shorter but still well captive when fitted, our problem is we have fitted it but its venting to atmosphere on idle, its not making boost according to the gauge but flutters when you back off we are planing on taking it off and checking every thing tomorrow night but can any one give us any pointers? thanks casey Quote
love ke70 Posted October 22, 2008 Report Posted October 22, 2008 id be worried too if my "waist gate" was venting when i didnt want it to... just keep adding washers til the waste gate does what you want it to. or cut the 16 pound spring :laff: Quote
DearmanKE Posted October 22, 2008 Report Posted October 22, 2008 by adding washers does that raise the level it vents at or lower it? Quote
love ke70 Posted October 23, 2008 Report Posted October 23, 2008 well he said the new spring was 20mm shorter than the old spring, and its now venting to atmosphere, so if you can add 10 mm to it, you'll probably be in a pretty good ballpark of where you wanna be :lolcry: Quote
DearmanKE Posted October 24, 2008 Report Posted October 24, 2008 I'm not sure how thecould be way off, but by spaceing the spring and compressing it more. then wont this make the spring release with less pressure to help it or do they work the other way in which the spring pushes against the pressure, so stiffening the spring would raise the pressure needed to open the gate ah yes it must work that way, much more logical once i think about it. Quote
Taz_Rx Posted October 24, 2008 Report Posted October 24, 2008 haha you getting confused cause of what I told you about BOV's on AE86 today? Yes waste gates open into the flow of gas, not pushed open by it. The boost line to a waste gate is what pushes it open. :lolcry: Quote
flat out Posted October 30, 2008 Author Report Posted October 30, 2008 surly not simon, surly the waist gate works pretty much the same as a bov? Quote
Taz_Rx Posted October 30, 2008 Report Posted October 30, 2008 Yes it does "work pretty much the same as a BOV", but in a different direction. VACUUM line on the top of a BOV basically sucks it open when there is post butterfly vacuum. BOOST line on the top of a wastgate pushes the gate open when desire pressure is reached. :) Quote
DearmanKE Posted October 30, 2008 Report Posted October 30, 2008 it all makes sense now, i wonder how a wastegate would go instead of a BOV in a blow through setup between the SC and carby... can have that to limit boost, and BOV to stop carby from blowing up. anyway getting offtopic sorry lol Quote
Taz_Rx Posted October 30, 2008 Report Posted October 30, 2008 Yeah that would work also with a boost line onto the wastegate. Could have like a screamer pipe that just vents compressed air, if it vents too much, boost will drop and WG will close up again. :) Quote
