ok, well i bought a 4k with a 5k elec dizzy, do i need to change my coil or can i leave him the same as stock one??
Need help urgently? and if i do need to change it what do i change it to?
Travis
Hey Travis
Go to a wrecker and get yourself a High energy coil or at least a Medium energt coil :P
It will work with the standard one but you aren't getting the full potential
Edited by KE ping it real
you could take of the ceramic ballast resistor maybe. but just goto the wreckers and grab a coil of car without points. I'm running a Bosch GT40 High energy coil on my ute which has an electronic ignition. Ive heard they are very good coils, havent had a problem with mine.
just a note, i know with Bosch and maybe other high energy coils have a part number starting with HEC (stands for High Energy Coil :P)
Edited by KE25 KID
  trav_555 said:
ok, cheers, and how much are they, dammnit i don't have any money since head gasket blew :P :(
Travis
I had a MEC running it and it cost me $20 from a wrecker, I think it was from a Falcon or something
You must use the correct coil to suit the distributer, Taking the ballast resistor off one thats meant for a points system will slowly kill it.
f@$k the shit bosch coils, Find a good denso one and you will never regret it..
When I got my 4KEU electronic dizzy, it came with an Echlin coil that needed a resistor, that worked perfectly fine...agree on the Bosch crap though, Denso stuff is heaps better
I got a coil that came off a RA60 celica, had Electric Dizzy.
Not sure if that coil would suit you, but ill check to see if its a HEC later and ill pm you if you interested. Just pay postage and she yours.
Dan
Dan
sounds good man. so long as its a hec, if you can find out the brand of it as well that would be tops.
thanks for reply's, and yea id prefer to get a hec one than wrecking my original coil.
Cheers
Travis
