Hey all,
After compatible and readily avaliable crossmembers that will allow me to bolt up my w series gearbos to my ke35.
All help appreciated.
P.S. don't say custom :) :)
yep, ONLY the 5 spd from a ke70 has the "4 bolt wedge" mounting you need.
All other k40/50 have the 1 bolt, and the wedge is 90o around the other way.
custom
they're easy and u can make sure it goes where u want it too
http://s29.photobucket.com/albums/c292/aro...nt=IMG_0047.jpg
thats just 50 x 50 x 3mm mild steel angle drilled to the bolt holes on the chassis
then a bit of angle across the bottom, can't remember size, with the holes drilled in the right spot, then just some braces welded to hold it all together.
never let me down, but I'm sure it could be better, like everything on that car
hey thanks guys, Ive found one from a ke70 5speed k50. ill post up later if it doesnt fit.
in regards to custom, I want it now, spend as little as possible, and when I do get pulled over which will happen, Id rather it look stock than stick out like dogs balls
cheers
