Le|Garage Posted September 15, 2008 Report Posted September 15, 2008 hey guys, got abit of an engine problem here. The car is a 1983 AE71 automatic. New spark plugs, ignition coil, leads, brake master cylinder, front brake pads When i start the car in the cold, i have to hold the throttle down and keep the revs at around 1200 for around 30 secconds before i let it go, or it will stall.. After that, It will drive perfectly, revs out cleanly. (it idle's at 1100 rpm). It wont want to idle any lower, when i adjust the idle screw, or it will splutter and stall. Standard factory setting is 800 rpm isnt it? Okay, now under heavy braking the car will stall. If i brake gradually, it is okay, but if i brake hard (like..normal braking), the revs will fall to around 600, and then it will try and catch itself and stall. I've been told it could be a "brake booster" problem? What could be the fix for these problems? Cheers! Quote
Trev Posted September 15, 2008 Report Posted September 15, 2008 Sounds alot more like a vacuum leak, Check out the vacuum hoses, When you have the car stationary in park/neutral and pump the brakes does it idle up? Quote
Le|Garage Posted September 15, 2008 Author Report Posted September 15, 2008 Sounds alot more like a vacuum leak, Check out the vacuum hoses, When you have the car stationary in park/neutral and pump the brakes does it idle up? I've tried checking all the hoses i know of, but i'm unsure which ones i need to check? I have got the air duct hose, the oil breather hose, a vacuum hose and some other thin hose going to the air filter box ontop of the carby. I've checked them and they all seem okay, is there any other one i should be checking? Does anyone have a vacuum line diagram? When i have the car stationary, and pump the brakes, idle doesnt change Quote
kryton brown Posted September 15, 2008 Report Posted September 15, 2008 It's also possible that the idle passages and/or idle jets in the carby are blocked. Quote
Le|Garage Posted September 17, 2008 Author Report Posted September 17, 2008 okay, well i set the timing with a timing light. And now it will idle at 800 rpm. It will sometimes jump from 8-850, but it idle's okay. Checked all the hoses going to the carburetor and their all fine. There are no hoses plugged to the heater core. COuld this be affecting anything? Still though, it will stall if i don't brake gradually, the revs will drop, real low and the car will stall when i brake. Any ideas? Could it be the brake booster? Is there any way i can check it? Cheers Quote
DearmanKE Posted September 20, 2008 Report Posted September 20, 2008 mine seams to drop in revs when applying the brakes but not so much as stalling, i would like to know why this happens to. Quote
Budowski Posted September 21, 2008 Report Posted September 21, 2008 Mine doesnt sem to drop much when i brake, but i can't get the idle mixture right or the fast idle. Isuspect i have semi blocked passages in the idle circuits but once off idle runs great. Ive checked every vac line all ok, havent checked the booster yet tho but i doupt its that. Quote
w13c Posted September 24, 2008 Report Posted September 24, 2008 i think the culprit is the 4ac's electronic/auto choke, mine is similar in that it idles at 1100, and revs drop heaps when you first accelerate. i took my filter off, and when i start up the auto choke doesnt budge, its just all floppy.. trying to figure a fix atm. Quote
AE80Rollaguy Posted September 25, 2008 Report Posted September 25, 2008 YEAH !!! i have pretty much the same problem but in reverse! today all of a sudden my 3ac idle's at around 500rpm and seams to be really fuely.. On the topic of webbers.. Has any one fitted a 32/36 webber to there 4ac? where could i get an adaptor plate from?? much help needed cheers Tory Quote
w13c Posted September 25, 2008 Report Posted September 25, 2008 haha yeah i was thinking the exact same , going the weber, i noticed this adaptor plate on ebay, if it helps http://cgi.ebay.com.au/WEBER-ADAPTOR-PLATE...Q2em118Q2el1247 Quote
Budowski Posted September 25, 2008 Report Posted September 25, 2008 going webber is very easy as seen on club 4ac Quote
orangeLJ Posted October 8, 2008 Report Posted October 8, 2008 (edited) how big of a bowl do the carbies have? Under heavy braking you could be experiencing some fuel slosh in the bowls, causing a loss of fuel, and the drop in idle. similar (but different) thing used to happen to an old torana I had, under full brakes or heavy accelerationthe float would move around in the bowl on the carb, causing it to flood. Is the carby in good condition? Edited October 8, 2008 by orangeLJ Quote
Budowski Posted October 10, 2008 Report Posted October 10, 2008 picked up 2nd hand carby a while back and forgot about it, its dirty as hell and when i dropped it in the car runs perfect after i adjusted the mixture and fast idle crazy eh :P, had a carby on a 97 hiace sent out for rebuild at work cost 185 dollars. Quote
Nitephyre Posted October 11, 2008 Report Posted October 11, 2008 I'm having these problems as well, but mine is manual. Brakes are spongy and the idle is shit... I so want a Weber again, they're great. Quote
mog_uk Posted October 29, 2008 Report Posted October 29, 2008 having the same problem, mine just started this morning, could it be anything to do with air in the brake lines/ effecting the brake master? I'm going to check - braking when stationary - see if idle increases check vaccum lines for brakes etc. afew people mentioned things to do with the carby. how and what do i need to check for? its a manual 4ac. -thanks Quote
