kpkilla Posted September 2, 2008 Report Posted September 2, 2008 Hey guys i am havn a lil trouble with my stock 4k it wont idle steady it keeps jumping from 900rpm to 700rpm ad is somethines causing itself to stall this is a real problem and makes the car surge wen not under acceleration so pretty uncomfortable i have recently replaced the spark plugs and points any help would b appreciated thanks. Quote
towe001 Posted September 2, 2008 Report Posted September 2, 2008 Have a check for air leaks around the intake manifold and the base of the carby. Quote
kpkilla Posted September 2, 2008 Author Report Posted September 2, 2008 towe001 said: Have a check for air leaks around the intake manifold and the base of the carby. have just replaced the gasket and no one bolt is missing wuld that be a big problem??? Quote
kpkilla Posted September 2, 2008 Author Report Posted September 2, 2008 Nick said: My old 4KC used to idle funny too... I learned to live with it yea i could do that but thea has to be a reason y its doing it i just want to fix it. Quote
PhoenixDX Posted September 2, 2008 Report Posted September 2, 2008 Have ya done the Timing with a timing light. As my 4k use to do what your describing. :jamie: If timing doesnt work, losen off the 12mm bolt holding your Dizzy in place and slowly turning it clockwise or anti- clockwise till you hear the motor running smoothly, be paitient coz the difference of a degree can change the idle. when the engine starts running true, then then you shouldnt have a problem with surging. Another thing that could be doing it could be your Mixture is to rich/ lean. have a play is your best bet. :P Quote
Palmy Posted September 2, 2008 Report Posted September 2, 2008 i had this same problem except my car didnt start lol. i had a gasket missing from the top part of my carby, new gasket and it was running perfect again. Quote
marksKE25 Posted September 7, 2008 Report Posted September 7, 2008 had the same problem this weekend, turns out it was a I a hole in the inlet manifold a big one. :D Quote
