hey guys i have recently taken the gay 4 speed out of my ke38 wagon and replaced it with a 5 speed. the problem i am having is the clutch pedal lets out really high, i have had a look on the pedal and i can't seem to find an ajustment. thanks guys in advance.
Remove the clip (or more commonly hose clamp :jamie: ) pull on the cable until its tight and re-fit clip/clamp. Have a play with different tensions till it feel nice and clutch doesn't slip. ;)
as they both said,
look for where the cable goes through the firewall.
should be a ridged section with an E clip against the rubber, pull the cable, remove the E clip, replace E clip in new spot and see if its better or worse.
