ae71wagonater Posted August 17, 2008 Report Posted August 17, 2008 Hey everyone, I have been thinking of rigging up an AE92 oil cooler setup onto my 20v AE71 wagon. I have read that some people think they are shit and i should get a full flow aftermarket kit, but I'm trying to save money. What are your thoughts on these cooler setups? Are there many 4age KE70/AE71's getting arround with this setup?. I have the sandwich plate and a sump with the oil return, and saw plenty of coolers at the wreckers. just have to adapt the oil return fitting onto a 20v sump. any suggestions a apprecatied. Cheers. :dance: Quote
reTRD Posted August 17, 2008 Report Posted August 17, 2008 my mate over here in NZ as got a worked blacktop 20V turbo in his kp starlet and he used a FD RX7 item as they have good flow rates in them factory. just a thought :dance: Quote
Budowski Posted August 17, 2008 Report Posted August 17, 2008 Hey everyone, I have been thinking of rigging up an AE92 oil cooler setup onto my 20v AE71 wagon. I have read that some people think they are shit and i should get a full flow aftermarket kit, but I'm trying to save money. What are your thoughts on these cooler setups? Are there many 4age KE70/AE71's getting arround with this setup?. I have the sandwich plate and a sump with the oil return, and saw plenty of coolers at the wreckers. just have to adapt the oil return fitting onto a 20v sump. any suggestions a apprecatied. Cheers. :dance: full flow depends on if your going to be holding the engine at peak rpm for say an hour on a race track or just a 15 minute blast throught the hills ? if your not really giving the car much stick for a long period of time i don't see why the AE92 oil cooler would be a problem, but if your sourcing a cooler from the wreckers see what else is available and check the specs online. Quote
Jono Posted August 17, 2008 Report Posted August 17, 2008 (edited) unless you give it prolonged thrashing you won't even need an oil cooler. i don't take my car to the track so i don't even use an oil cooler. it takes ages of boosting around before the oil temp will nudge 100 degrees, takes a while for the oil temp to get to 85-90 but once its there its pretty stable. Edited August 17, 2008 by Jono Quote
Budowski Posted August 17, 2008 Report Posted August 17, 2008 unless you give it prolonged thrashing you won't even need an oil cooler. i don't take my car to the track so i don't even use an oil cooler. it takes ages of boosting around before it will nudge 100 degrees, takes a while to get to 85-90 but once its there its pretty stable. agreed Quote
ae71wagonater Posted August 17, 2008 Author Report Posted August 17, 2008 thanks guys, yea shes just a daily driver that i give a bit of a boot too, i thought she might have been getting a little bit warmer than normal, which was resulting in a little pinging, due to something with the water system but it seems to be stable arround the 85-90 degree mark now, however it is FKN cold at the moment so I'm wondering how it will be in summer. cheers everyone. Quote
