Thanks guys will try some of these,i tryed some new environment friendly degreaser it was rubbish.
Environmentally friendly is code for it doesnt work that great,unless you use 10 times the amount.
thanks again rob
Gasket Remover. Usually used to get crusty head gasket of heads and blocks, but I used it with great sucess to get a stack of oil and grime off a rocker cover the other day.
hey i have a friend that works for autologic, and their degreaser is the best i have ever come across, it cleaned all of the really dity oily stuff, however....
you can use it neat but it not advisable, as if you leave alloy to soak in it, it will melt it and neat.
cleaning products
cleaning products
Holy shit - dissolving the alloy!!!!!!!! mmm lightened alloy components for the win :no2:
Yeh alkaline/caustic substances will eat Aluminium (shouldn't call it Alloy - Steel is an alloy too!)
I'm not sure what the gasket remover was, It must be aluminium compatible because of the number of aluminium blocks/heads out there. Do a test patch with whatever stripper you use, it'll be fine!
Me bad - as a metallurgist by qualification I got lazy.
