TOYRLA Posted August 14, 2008 Author Report Posted August 14, 2008 yeah its the stock purple. i'm running a t28 turbo but don't know what injectors to get Quote
Taz_Rx Posted August 14, 2008 Report Posted August 14, 2008 what have you got at the moment, like size wise? 7MGE or 7MGTE one will bolt straight in and are bit bigger than 4AGE ones. ZE ones are big though. Quote
Jono Posted August 14, 2008 Report Posted August 14, 2008 how much boost you going to run? i think i remember hearing GZE (365cc) run out at 15psi but i'm 100% on that. i'm using GZE injectors in my setup. Is your motor just an NA smallport? I'm putting 10psi through my NA smallport and its fine. Quote
HIGH ROLLER Posted August 14, 2008 Report Posted August 14, 2008 (edited) Jono said: how much boost you going to run? i think i remember hearing GZE (365cc) run out at 15psi but i'm 100% on that. i'm using GZE injectors in my setup. Is your motor just an NA smallport? I'm putting 10psi through my NA smallport and its fine. I've herd the same, 365cc good for 15-17psi...shouldnt be too hard to find some... If you can wait keith, i'll be using 550's when i boost mine ;) wont be for a while tho...haha Edited August 14, 2008 by HIGH ROLLER Quote
TOYRLA Posted August 14, 2008 Author Report Posted August 14, 2008 thanks for the help boys, if i can find some gze i will get them. Quote
HIGH ROLLER Posted August 14, 2008 Report Posted August 14, 2008 TOYRLA said: thanks for the help boys, if i can find some gze i will get them. Try www.toymods.net on the for sale threads, plenty of GZE stuff there... or post up a "wanted" thread here or there...you'll find some for sure Quote
HIGH ROLLER Posted August 26, 2008 Report Posted August 26, 2008 I herd some hollywood gossip that you got some more parts.... might just be gossip tho...hahaha More PICS!! MM Quote
TOYRLA Posted August 27, 2008 Author Report Posted August 27, 2008 yeah its true. i just got the starter and also had some brand new parts imported, like side lights, speedo cable, clutch cable and more new gifts for the rolla Quote
roladude Posted August 27, 2008 Report Posted August 27, 2008 now you definetly need to show more pics please Quote
Jono Posted September 26, 2008 Report Posted September 26, 2008 whats the clutch cable for? aren't you going hydro? Quote
HIGH ROLLER Posted February 26, 2009 Report Posted February 26, 2009 This project is finished, yeah? come on keith get off the sky-rii-nahh and on to the rolla... Quote
Doogs Posted February 26, 2009 Report Posted February 26, 2009 Good work. Looks like there is a lot of work in that body, good on you for giving it a go yourself :lolcry: Quote
