mundawg Posted August 4, 2008 Report Posted August 4, 2008 hey everyone. The time has come to put my 4age (blue and black top) into the ke70. Having a few issued with the oil pressure sender. Was wondering what type of sender i should run? I have a guage that came with a sender and not sure if that sender will work. do i need to run a sandwhich style unit. heres a few pics. any info at all would be great. cheers. Quote
Medicine_Man Posted August 4, 2008 Report Posted August 4, 2008 Put it in the same spot the old oil pressure switch would have been.. If you want to run both the switch and sender you will have to get a T piece.. Quote
mundawg Posted August 4, 2008 Author Report Posted August 4, 2008 Medicine_Man said: Put it in the same spot the old oil pressure switch would have been.. If you want to run both the switch and sender you will have to get a T piece.. Thanks Medicine_Man, I was mainly not sure if thats where it was ment to go. When i got the motor that hole was pluged so i checked my mates motor and thats where his oil pressure switch is. His motor is in a FWD car and the motor i have is RWD. So thats why i thought maby i needed one that goes between the block and the filter or somthing. Cheers Quote
