pen15 Posted August 2, 2008 Report Posted August 2, 2008 is there any differance in the front struts from a ke70 to an ae86 if so can some1 please tell me i would also like to know if i have front ae86 struts in mine i think i do because thay look a little different all i reallt wanna know is if ae86 camber tops will fit in ke70 front struts any info would be really helpfull thanks Quote
Trev Posted August 2, 2008 Report Posted August 2, 2008 is there any differance in the front struts from a ke70 to an ae86 if so can some1 please tell me i would also like to know if i have front ae86 struts in mine i think i do because thay look a little different all i reallt wanna know is if ae86 camber tops will fit in ke70 front struts any info would be really helpfull thanks The ae86 cartridge is larger (50mm), Yes they do but you have to use the ke70 tops on the ae86 struts (if you are using standard tops). Quote
