okay lads,
seeing as ive got some spare time on my hands i thought i would post up my latest project.
it is a track only te72 (t-18 for those of you playing at home).
its stock as a rock, body is relatively tidy with only some minor rust around the hatch seal and a bit of bog they had fallen out of the front guard from a previous repair. never mind though as i have a spare pair of front guards and a heap of other spares that came with the car. guards will get flared anyway so thats not an issue. the 3t and box are in overrated condition and are from a S2 (a few years younger).
my plans are to turbo the 3t as they are a very tough motor and respond well to boost.
so here are the future specs
motor/box:
3tc
t28 (picking up this weekend)
top mount cooler, probaly an fc rx7 one
blitz bov (picking up this weekend too)
32/36 weber
boost gauge and controller
side pipe
electric fuel pump and regulator (unless i manage to be able to ghetto up a system to get it to optimum pressure without a reg)
will get it going with the t-50 and stock clutch, will have to upgrade the clutch as it probaly wont handle this sort of power increase. box is overrated so should last quite a while.
will be using either a ke70 bogy or s-series, locked of corse
body/susy:
removed every bit of equipment thats not essential for it to run/safety will be keeping gauge cluster tho.
rear and quarter lexan windows
10kg front springs (currently in my road car ke70)
chopped falcon or stiff similar rear springs
probaly some new shocks/pads
spot weld a lot of the car especially engine bay, front home made brace
longer lcas and custom camber tops
possibly twin rear sway bar/ghetto larger swaybar
wheels:
will be using what ever i have spare,
probably wither 14x7 or 15x7 fronts and 14"s for the back, with spacers if nessesary
other rice bits:
rear wing of some sort,
bonnet vent/scoop for cooler may have the cooler mounted threw the bonnet not sure yet.
new white pressure pack/cheap paint on the green panels so its one colour.
quad headlights most probaly or GT series 2 lights
cheap harness
old better steering wheel
you want pics?
yeah machg, ive seen your build thread, that thing was massive rusted.. personally i wouldn't have started it but neither the less, good work on it man.
  tas_ae71 said:
you want pics?
OOOO!!! She's soooo pretty!
  tas_ae71 said:
you want pics?
Not urs! :bash: Steering wheel is on the wrong side
hahahah i wondered how long is would take, bingo
would be aiming for something like that maybe not quite so clean.
some pics of the real car hahah
note the tow bar has been removed (saved 10kg) and the rotor spec exhaust will be ditched for a side pipe
nice and dirty engine bay. don't be fooled, under all that grime is a very good condition motor, perfect base to start from. motor has been transplanted from a later series 2 t-18
okay, a quick update of newly accured parts
turbosssss
brand new cooler, still planning to top mount it either angled with a scoop or straight up.. could look a bit dodgy but i want it top mounted.
genuine blitz boost gauge.... now just have to figure out what psi is in kg/cm2 hahaha
Edited by tas_ae71
Damn you must have a sore spine from 10kg springs in a daily driver, is it choppy over the bumps? KE70dave's car was terrible with 10's and only just bearable with 8kg springs.
BTW, I'd keep your tow bar, and just loose the tongue. Old rolla's are soft in the tail and linking the 2 rear rails with reinforcement gives a very noticeable stability at high speeds.
nah tow bar kinda got stolen haha..
the sort of steel they use is heavy as smeg too, will be seam welding and maybe some bracing/half cage.
yeah you just harden the smeg up, 10kg isnt that bad... better than welded shocks. just.
wouldnt be so bad with some shocks to match it. but it does mean that you can have it sitting on the tyre without and scrubbage when when you get air over bumps.
