My clutch master cylinder is dumping its contents onto my left foot and i've noticed the clutch master cylinder off other toyotas look similar to an AE86 one. Is it possible to one of these instead of an AE86 one?
You can also use some old school celica parts...it requires a little fabrication but its do-able. I'm not 100% sure which models are compatable...i think the ra23 is but i'd have to clarify
the ae86 cylinders are well known for their tendancy to leak...a few people i know with gze & gte have gone down the custom track ie:cusco
twinky ones should work also...can't see there being much of a difference
i'll see what reliable info i can dig up for you
I have the same problem with my sprinter u should be able 2 do a simple rebuild 4 not much at all mine is not as bad as yours but will be soon. If i find out a better way ill let ya know.
Hachi Roku
Co founder of Team Phatoyz
toyota actually used the same master cylinder on a lot of different models....its fairly common to come across...
hrmm, i'll see if i can locate a part number....may be useful
i can't locate any part numbers....best i could come up with is this
http://www.yankeetoys.org/docs.htm
came through on toymods start of this year...its a european parts catalogue...doesnt have any JDM part numbers but there is some info in there thats prolly handy...the first 6-7 part numbers are apparently universal
2 files...500mb each...i havent actually seen it as theres no way i can get it through dialup but if someone wanted to d/l and have a look at it, perhaps pilfer a few part numbers for the tech section
  Grimwolge said:
This is a reminder to myself to archive this in the new Tech articles section :KY:
*please ignore*
don't forget to archive this in the technical section dude ;)
