sam k Posted July 4, 2008 Report Posted July 4, 2008 hey everyone I'm looking at laithing both my primary and seacondary venturis. The engine I have is a 3K-C and I belive that the standered venturis are, 21/24 mm What would be the largest size you would recomened, the take them out to, it is only a 1200cc! any help would be appreciated. cheers Sam. Quote
calaissix Posted July 4, 2008 Report Posted July 4, 2008 hey everyone I'm looking at laithing both my primary and seacondary venturis. The engine I have is a 3K-C and I belive that the standered venturis are, 21/24 mm What would be the largest size you would recomened, the take them out to, it is only a 1200cc! any help would be appreciated. cheers Sam. don't bother,it will upset the flow of the carby,if you want greater flow buy a larger carb. Quote
philbey Posted July 5, 2008 Report Posted July 5, 2008 Sounds like nonsense but bigger venturis will give less performance. Venturis are designed to accelerate the airflow through the carb. The acceleration creates a pressure drop that pulls the fuel from the bowl. Larger venturis = less pressure drop = less fuel pulled out of the bowl. You may be able to improve on it, but it may just as easily got pear shaped without a bit more diggin. Quote
sam k Posted October 8, 2008 Author Report Posted October 8, 2008 Hey guys a bit of an old topic but i recenlty replaced my seacondary venturi and i have noticed some increase in the power when its working, also gives a deeper induction noise. Quote
Boost+k Posted October 9, 2008 Report Posted October 9, 2008 and you can't machine them... there too poris, i've tryed, theres bigger ones out there my turbo carb has 24/29 (if i remember right) but you can't really go bigger than that, my secondary isnt really much of a venturi, but its only there for boost so it doesnt matter to me lol Quote
philbey Posted October 9, 2008 Report Posted October 9, 2008 Increasing venturi size can definitely improve performance, but too big can decrease performance. All about sizing it correctly. Quote
coln72 Posted October 11, 2008 Report Posted October 11, 2008 If I remember correctly, Super Jamie, had a thread on this on the "oldcorollas" forum..... Quote
towe001 Posted October 14, 2008 Report Posted October 14, 2008 When he had the '25 Which was a few years back Quote
