ausca62 Posted July 1, 2008 Report Posted July 1, 2008 (edited) New member needs help. I am in the process of fitting 2tg head to 2t block and I want to know the best way to block off the oil holes in the unused cam bearings. I have been told to just rotate the bearings but it will be an expensive lesson if it fails. Cheers Paul. Edited July 1, 2008 by ausca62 Quote
SeptemberSquall Posted July 8, 2008 Report Posted July 8, 2008 New member needs help. I am in the process of fitting 2tg head to 2t block and I want to know the best way to block off the oil holes in the unused cam bearings. I have been told to just rotate the bearings but it will be an expensive lesson if it fails. Cheers Paul. rotate the bearings Quote
styler Posted July 16, 2008 Report Posted July 16, 2008 x2 it just the way its done. you could make a ring exactly like the bearing (id/od/width) with no hole if you like and press it in. but most people accept the fact that no ones going to bump into the unused rotated cam bearings by mistake and let the holes line up letting oil through. Quote
