hey guys I was looking into a set of Type-RS RX7 rotors and calipers if I can fit them onto my KE25 - if not I might go a brake upgrade kit which gives me practically the same size however in both situations i need a 1" bore master cylinder. I have a brand spanking new series6 rx7 brake cylinder which I don't need for my rx7.
is it possible to fit this to my KE?
cheers guys :(
I don't really want to be buying yet another master cylinder lol, am already spending plenty of $$$$ on it.
Thats good info though - Jono, is that from a DC2 model integra? possible to get a pic of the setup under ur hood?
also what did you do with the rear brakes, still running drums on the rear or did you upgrade the rear to disc as well?
my drums are absolutely scr**ed cause of the dumbass before me putting the shoes in them the wrong way and looks like 1. It's going to be hard to source some replacement drums that fit, 2. It's going to be damn expensive too
awesome, cheers man ;)
yeah not sure what I'm doing for the booster yet - will be a 13BT conversion (cause we rock in NZ and can get away with it!!) so will probably look into a booster later down the track when I get a 13B block mocked up :(
Edited by Jarsky
